PHD - 1st Experience
/ PHD - 1st Experience #21
Hi Guys,
Do you have any tips regarding cutting blades? I drilled first four holes (out of 86 !) last week like butter. Next hole was in very rocky (6" stuff) soil and I think the cutters got worn down quite a bit! Every hole thereafter wouldn't go beyond 1' deep even in fairly loose dirt. I'll stop at my ag dealer today and pickup some additional cutting blades.
The PHD is a Befco Mole with 12" Auger. Drilling holes to about 3 1/2 ' for high tension charged fence. (Keeping deer and other critters out of my new vineyard!)
Thanks in advance for any advice,
Tony
/ PHD - 1st Experience #22
You can sharpen the cutting edges with a grinder. It sounds to me like your bits were not properly hardened and tempered. Small rocks in one hole should not have dulled the bits. The bits should be hardened but tempered to make them less brittle so they don't break easily. If you have too much trouble with them dulling you may be able to get hard surfaced bits. There is a lot of difference in the quality of augers and bits.
/ PHD - 1st Experience #23
Have used a PHD before on tractor but last time
I asked dealer to demo one for my skid loader, hydraulic
drive.Down pressure and move side to side to align.
FAR better than PHD on tractor.
/ PHD - 1st Experience #24
centex,
For new cutting edges, a neighbor of mine used old springs to make new cutting edges. When one broke or got dull, he would cut out a new one and weld it on. He helped me put a fence in a few years back and he could cut, weld, and sharpen a new blade in less than a half an hour. And the cost was very cheap - got some springs off of a junked car. So, a little electricity and acetylene/oxygen.
Terry
Well, I got more 'sperience' yesterday /w3tcompact/icons/smile.gif. My wife and I marked the spots for 20 posts yesterday. My original plan was to drill all the holes on Saturday, then get the posts the following weekend and install them. This is to break the job of installing 185 posts into a managble project from a time and budget perspective plus I don't have a place to store 185 posts!
As I said, that was my original plan...Of the 20 spots we marked I got exactly 3 holes dug after working all day. /w3tcompact/icons/sad.gif In each hole I hit rocks less than a foot into the ground. Not single big rocks, just medium size rocks that necessitated stopping the digging, moving the tractor and using a digging iron to get them out. Then repositioning the tractor to continue digging.
On the bright side, someone's recommendation here on TBN of leaving the rear PTO engaged (tractor engine off, of course!) when changing a shear bolt worked great. It allowed me to turn the auger by hand without the driveshaft turning which made it easier to line up the holes in order to knock the broken bolt out (I broke 2 bolts). I also bought two 9/16" box end wrenches to make installing a new bolt easier. I had been using two 10" adjustable wrenches. The box end wrenches take up less room in the tool box and are faster. The adjustables were fine when I didn't think I'd be breaking so many bolts. /w3tcompact/icons/laugh.gif While I was at the hardware store, I also bought more bolts. Interestingly enough, the shear bolts I bought from Leinbach are 2.25" long. Neither TSC nor the local TruValue had them, so I had to buy 2.5" long bolts. They're Grade 2 and the additional .25" wont interfere with anything.
I also discovered that as the temperature goes up, my patience goes down /w3tcompact/icons/mad.gif. So, I kept that in mind as impatience and a tractor can easily result in making a disagreeable situation worse. When I felt patience wearing thin, I took a break. Not a bad idea with temps in the 90s.
Oh, on one of my rest stops my wife told me that the air conditioner in our bedroom was producing nothing but hot air. (She refrained from drawing the obvious analogy to me. Bless her heart! /w3tcompact/icons/laugh.gif) So, I got to go look for a new air conditioner last night. Sears was the only place that had ones even on display. They had none in stock except the bazillion BTU, 'you need a picture window sized opening to install it' models or ones for casement windows. I offered to buy the display model which would have been ideal but they wouldn't sell it to me. They said if they can order the model, they can not sell the floor model. Sigh. So, I ordered one. They claim it'll be in on the 8th. We'll see. My local Sears is sad, I don't see how they stay in business. It took the salesman 45 minutes to determine what they had in stock since he had to actually go look instead of trusting the online inventory. (I noticed their registers are CompuAdd PCs!!! CompuAdd hasn't been in business for years). When I ordered the air conditioner I did not have my Sears card with me. No problem. Enter your SSN and your card number will appear. Er, um, someone elses name showed up. Guess Sears card number database is as accurate as their inventory database! /w3tcompact/icons/laugh.gif I ended up using my Visa card.
Sears was a place my Dad always shopped for tools and it was a great place. It's sad to see what they've (at least the ones in our area) become. I only go there when I have to.
In case you're wondering what I think is a lot of rocks, see attached. I had to stop digging and clear the rocks from the hole at least 6 times just to dig one hole. While this might not look like many rocks, the problem is when they work together to bring digging to a stop. It only took 90 minutes to dig two holes this morning, while it was still coolish, so my average time per hole is coming down. /w3tcompact/icons/laugh.gif
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
2005 FRAC TANK 500BBL WHEELED (A60736)
2005 FRAC TANK...
Iranch IRGC40 (A60463)
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
