Personnal Info editting problem
/ Personnal Info editting problem #1
Hypernix
New Brunswick, Canada
John Deere 4110
Hello,
Has anyone noticed that when you edit your personnal info, you loose part of what was in the Attachment field?
For example, I had
"410 FEL, 60" MMM, 54" Puma Snowblower, 60" Buhler Tiller"
After I filed, I had
"410 FEL, 60"
So I retyped everything and now it's OK again... hummm..../forums/images/graemlins/confused.gif
Hypernix
/ Personnal Info editting problem #2
<font color="blue"> "410 FEL, 60" </font>
This issue was brought up once before, and I had the same problem at one time myself...
After you put the quotation mark after the 60, it cuts everything else off. Try putting in 60 inch instead and see if that works. /forums/images/graemlins/smile.gif
AndyM,
Thanks! Yeah it now makes sens, that double quote would in fact affect the script processing the input form... Geezzz I should have noticed this /forums/images/graemlins/blush.gif
Hypernix
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
(4) Tractor Wheel Weights (A65640)
(4) Tractor Wheel...
John Deere Z915E Zero Turn Mower (A66408)
John Deere Z915E...
2017 FORD F-750 SUPER DUTY (A65643)
2017 FORD F-750...
Husqvarna MZ61 Zero Turn (ZTR) Mower (A66285)
Husqvarna MZ61...
New 43X16-20 NHS tire on 6-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 43X16-20 NHS...
