Pedal tractor puller build
/ Pedal tractor puller build #4
"Chances R" ,great idea and beautifull work ,great detail and built to last,the color would make me think you have some Agco background or tendancies.
/ Pedal tractor puller build #5
I suppose AGCO tendencies is better than John Deere OCBs.
/ Pedal tractor puller build #6
WHAT A GREAT BUILD!!
Sure like to see more pictures of it and details of how it looks inside the peddal tractor.
Thanks for posting!:thumbsup:
Here is the link to more pictures.
http://photos.imageevent.com/hand_cranker/pedaltractorpullingsled
As far as liking certain brand of tractors I like them all. I collect antique tractors.
Some of the stuff you need to know is the sprocket ratio is 2.5 to 1. 3/4" axle and pedal shafts. Both rear wheels pull. Rear axle has 2 roller bearings pressed in to the aluminum plates and then brass bushing/bearings pressed in to the axle housing ends. Front weight is a solid chunck of aluminum. Fuel tank is aluminum round stock. Custom hitch tied to the frame and origional hitch. Fun build but it did take longer than would of thought. Total investment around $800.
There is also a facebook fan page at Play 'N' Hooky pedal tractor pulling LLC.
/ Pedal tractor puller build #9
Nice build! Pedal pulling tractors are serious business in our part of the country. They have a pedal pull in Franklin County, Indiana in September that is awesome. I go there every year.
JOHN DEERE 4450 TRACTOR (A64278)
JOHN DEERE 4450...
UNUSED PARBREAK AR650 HYD AUGER SET (A65055)
UNUSED PARBREAK...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
