PaulB Rotary
/ PaulB Rotary #51
Re: NH TC33 Rotary
Thanks to all for the responses. I'll look closely at the 5' cutter to be on the safe side. I'd rather have to make a couple passes than not be able to get in-between something.
Mike H - Did you purchase your KK @ QF&F on Airport Road in Jackson?
What size blade should I buy for the rear of a TC33D; 60", 72" or 84"?
I'm also looking at the Scarifier/Rake combo set-up from Land Pride (Series 25). We have heavy clay soil that I need to "de-rock", smooth out and grow a lawn on. What's a good width: 66" or 77"? - Thanks
/ PaulB Rotary #52
Re: NH TC33 Rotary
I purchased the KK rotary cutter at the QF&F in Portage (because I work in Kzo it was convenient). If you do go with the KK, I found:
- I had to loosen the bolt on the rear wheel so it would rotate
- remember to grease and oil since it comes unlubricated
- when you assemble it, you put a pretty good bend in the front to rear braces to install
- I've got some bracket in my shop that I never figured out what it was for (so the instruction manual's pretty weak)
- It doesn't come w/ any guards so be careful ( I got whacked in the head w/ debris just to prove this to myself!)
I'm going to get at least a 72" rear blade before snow falls - I do want that wider than the tractor. This should work a little better than the 48" plow on my garden tractor!
/ PaulB Rotary
Re: NH TC33 Rotary
The brochure I have shows that the TC33 is rated for a 60", 72" or an 84" rear blade. I use a 60" on the mighty TC18 and it works great. Some here on the board have recommended that the blade cover your tracks even when angled. I would think you would want to go at least 72" if not bigger. Have you owned a diesel before? If not, you'll be amazed with what 33 hp will do, I am amazed at my 18.5 hp! /w3tcompact/icons/cool.gif
Enjoy!
JimBinMI
We boys and our toys!
/ PaulB Rotary
Re: NH TC33 Rotary
Mike H & other Michiganders,
QF&F is building a new store in Battle Creek on Beckley Rd. right next door to Lowe's! Can't wait it's one of my favorite toy stores along with TSC, any hardware, any electronics, .... You know the old saying, he who dies with the most toys wins! I'm not even close, but I'm still semi-young. /w3tcompact/icons/smile.gif
JimBinMI
/ PaulB Rotary #55
Re: NH TC33 Rotary
Sounds like a 72" or 84" blade. Any comments from anyone on the Scarifier/Rake combo set-up from Land Pride (Series 25)?
Any thoughts on the 60" cutter vs. something wider?
Yes, I'm a familiar w/ the diesel engine as a workhorse. Can't beat 'em. Maybe these gas prices will get this country thinking about diesel, again. Europe has been keen on diesel for years. You can't go wrong w/ anything that's a DI, intercooled Turbo Diesel, except for maybe throwing in a VGT (Variable Geometry Turbo [no wastegate]).
Thanks for all the inputs…, . JayD
/ PaulB Rotary #56
PaulB,
Did you solve you cutter height adjustment problem? I've been puzzling over how to get mine a little higher off the ground.
Glenn
/ PaulB Rotary #57
glennmac - I learned to live with it. On my ground I never need to lift the rear wheel off the ground, so I left it as is. To fix it I would have to drill new holes for the 3 point mounting pins lower on the mower frame. Not a big job, but one I decided to leave well enough alone. Did you fiddle with the lift arm mounting holes on the lower lift arms? I guess they put different holes because some will give more leverage/less lift, and others less leverage/more lift. Seems intuitive that the farther out you mount the lift arms (more toward the implement) the more leverage/less travel, but someone who knows for sure should confirm this before you try anything.
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2017 Ford F-250 (A55973)
2017 Ford F-250...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
