PaulB Rotary
/ PaulB Rotary #41
wen, on position control there three holes on draft four holes they are to adjust for soil conditions for plowing, etc. bottom hole is for harder ground also for mowers, both mid and rear mount
/ PaulB Rotary #42
wen,my manual says with position control there are three holes, on draft control they are four. the harder the gound the lower hole you need to use. for plowing that is.for mowing you also use bottom hole.if draft control is to be used draft resonse is more sensitive when top link mounting holes are used.
/ PaulB Rotary #43
Mike H:
If you have a TC33D why didn't you go for a 6' rotary to cover the width of you tractor? I put a deposit on a TC33D and have started the implement search. - JayD
/ PaulB Rotary #44
Jay, I don't own a TC33, so take this with a grain of salt. /w3tcompact/icons/smile.gif
While there are 6 ft mowers that are pretty light, Rhino, Bush Hog and several name brands are about 700 pound for the light duty mowers and 950 pounds for the medium duty mowers. Since that 700 pounds is located way behind the tractor, it can be a problem simply from the weight. General rules are that 6 ft equipment usually is recommended for 40 pto hp tractors. It doesn't take 40 hp to cut grass with one, but in heavy damp grass, and going uphill, the hp load is not insignificant. The other problem is that the 3 point can pick it up, but the tractor steering gets light because the weight on the front decreases. You can easily overcome this by using a front end loader which easily counter balances the rear load or by adding weights on the front.
Get the dealer to loan you the operating manual for your TC33. It should have detailed recommendations for the implements that it is compatable with. /w3tcompact/icons/smile.gif
/ PaulB Rotary #45
I've noticed several people have mentioned using a front end loader for front weight when mowing, and of course, it'll do what it's supposed to do, i.e., keep the front wheels on the ground when you pick up the loader. And I guess in many areas, that's fine, but so much of my mowing is rough ground that I found the weight of the front end loader that far in front of the tractor causes the front end to bounce up and down more. It sure is a lot smoother ride and less tiring to do my mowing without the front end loader on the tractor. Of course, my mowers are small enough the tractor can handle them without additional weight on the front end.
Bird
/ PaulB Rotary #46
Good point, Bird
I had that problem with my Massey 245 and Great Bend Loader. It bounced on rough ground and really limited mowing speed.
I think the M6800 is a lot heavier and the loader is a lot better made. This combination works about the same either on or off. The front tires are also much larger and that helps stabilize the loader, too. This loader comes off with no tools very easily. The Great Bend was a lot of work to take off and stayed on.
One other real difference now is that I have a quick attach bucket. Takes a few seconds to remove the bucket which gets rid of several hundered pounds and also provides a lot of clearance for mowing and not hitting things with the bucket. It also does not block the lights when I have to have them on (seldom).
/ PaulB Rotary #47
Yeah Wen, these quick attach loaders are great. My little B7100 loader was not a quick attach and was never off, but this little B2710 loader goes on or off so quick and easy that I never have it on for tilling or mowing. Of course, a bigger tractor makes a big difference, too./w3tcompact/icons/smile.gif Yours is up there in a different class./w3tcompact/icons/wink.gif
Bird
/ PaulB Rotary #48
As I think about it, I suppose I had several reasons:
1. Exactly what Wen said. I spent a fair amount of time researching all this "stuff" (I'm referring to learning about tractors for somebody who's never owned one) and the rule seemed to be use a 5' for a 33 hp tractor. By the way thank you Bird and Mark (and all you future poster winners!. I researched tractors for over a year - much from this forum - and being able to lurk and soak in you experience/expertise was a tremendous help.
2. I asked my dealer. When he delivered the tractor, I pointed to my pasture and asked "what size?". His response was "a 5' is perfect for this".
3. I went cheap on the cutter. This was intentional because I really didn't know what I needed. I've had a small number of horses on 15 acres for a dozen years and the pastures have never received any attention. They're only 70% pasture now and I assumed that what I needed for chopping the thing back into shape and what I'll need for mowing grass might be different.
I've only mowed once so far. I could easily have handled a bigger cutter where it's just grass; but I had to be careful with saplings. When they're all gone and I've got decent fence lines, I may be smart enough to know what I actually need and the worst case situation is I used up a cheap cutter. I never once considered tractor width in picking the cutter.
Good luck w/ your TC33. So far I'm quite pleased. Only problem: I got the backhoe installed last weekend and spent it digging out stumps. Like another discussion topic about the "mowing wife", my son loved the backhoe action. I got to move the tractor from place to place so he could put his Nintendo expertise to work!
/ PaulB Rotary
Re: NH TC33
Wen,
Are the Operating Manual and the Operator's Manual different? My TC came with the Operator's Manual, however, though it gives great information it doesn't state implement sizes for my tractor. The sales brochure does state implement sizes.
JimBinMI
We boys and our toys!
/ PaulB Rotary
Re: NH TC33 Rotary
Mike H,
Just looked at the brochure on the TC18-33's and yours is rated for a 5' or 6' rotary cutter. In fact from TC25 up to yours you can use either a 5' or 6' rotary.
Since my TC18 will handle a 4', I know that your TC33 would have to handle a 6' with no problem! But it's just fine and dandy with me that you went with the 5', you might even be able to take out a couple of oak trees with that baby! /w3tcompact/icons/laugh.gif
Good Luck and enjoy that awesome piece of machinery!
<font color=blue>Referring to the TC here!</font color=blue>
JimBinMI
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
207270 (A52708)
207270 (A52708)
2007 Barber 600HD 76in. S/A Towable Beach Rake (A59228)
2007 Barber 600HD...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
