Pat's Easy Change Vs Quick Hitch
/ Pat's Easy Change Vs Quick Hitch #61
I use to have a HF and bought the Pat's and really like the them so well that I installed a hydraulic toplink :D:D:D THAT'S THE WAY TO GO!!!
/ Pat's Easy Change Vs Quick Hitch #62
Truth be known Pat's is the way to go! I didn't go that way because i have 2 tractors and the cost to do 2 tractors is a bit higher than i could go. I got my first HF quick hitch at a garage sale for 5$. The owner said it was junk and it wouldn't work. Guess i was a bit smarter than the hitch. After some modifications all but on piece on equipment works with it. Just bought a second HF QH for 49.95$ @ the store because it was damaged goods, well the box was. My Mahindra hitch is a little tough to hook up to but the Kioti with adjustable lift arms is real easy to hook to! I really wouldn't even need the QH but the price was right. If i had to do major work to make the implements match my hitch it would be Pat's for certain!. . .John
Black Friday discount pushing me toward making this purchase. Definitely decided on PEC. With no Cat 2 implements, gut feeling is to purchase the Cat 2 to Cat 1 and not have to deal with any bushings. So far have not had any issues damaging any of the Cat 1 implements.
Any last words on insisting on going with the Cat 2 PEC?
/ Pat's Easy Change Vs Quick Hitch #64
I decided bushings are cheap and once they go on they never have to come off of the old implements and stay Cat 2 ready.
I guess the hang up is there are currently no Cat 2 implements, not sure there ever will be. All other tractors are fixed Cat 1 which encourages purchasing Cat 1 implements so to not be tied to the one machine that can use them. Thoughts of if got in a bind and the Cat 2 tractor was down could simply swap machines and keep going. Not sure this would ever happen, but you never know.
I guess your view would be to just store the Cat 1 to Cat 2 bushings on the Cat 2 tractor and "bush up" on the implement as needed?
/ Pat's Easy Change Vs Quick Hitch #66
That's what I'd do...
Bushings (and the roll pins) are pretty cheap...just don't buy them at your Deere dealer (then they're made of gold). Tractor Supply, Agri-Supply and others; have them (probably online too). The bushings kit (lower links only) cost about 10 bucks.
I had the PEC on my old 790. I have a Quick-Hitch now and there are times I wish I had kept the PEC.
Thanks for the quick responses and offers of opinions. Planning to go with the standard Cat 2 and move forward. Truthfully have been using the Cat 2 hitch on the Cat 1 implements without issue, but will make plans to invest in bushings to tighten up the fit. This seems safest way to proceed and doesn't put the PEC in a position to be the "weak link" in the equation.
/ Pat's Easy Change Vs Quick Hitch #68
It looks like it may be April till I get around to using the QH, so there's plenty of time to develop a plan. When giving the hitch a once-over before putting it in the shed, it's obvious some tweaking of existing implements will be necessary. I dropped the RFM yesterday and hooked up to the scraper blade. Typically that stays on till the grass starts growing again.
1. The scraper blade frame is such that a piece of steel below the top pin will block the top hook of the QH from grabbing it. Not a big deal to rework that, and it could be the same on other implements. After building the cab, reworking a piece of steel here and there is small stuff - and it only needs done once.
2. More head scratching comes from looking at the RFM. It is designed so the toplink attachment to what I'd describe as a swinging clevis presents more of a challange. If that were eliminated it looks like the RFM won't be able to follow the ground contours. With the swinging clevis arrangement the mower deck can ride over the ups and downs. Eliminating the swing action it looks like the deck will want to remain on the same plane as the tractor, raising the rear wheels off the ground when cresting a rise and rainsing the front wheels when coming to the bottom of a hill. How do you deal with that? I'm pretty sure I could come up with an arrangement that would still allow movement but am not anxious to redesign the mounting frame.
/ Pat's Easy Change Vs Quick Hitch #69
Before you go too far, look in your manual, if you have one for your RFM.
I bought a used Woods Bush Bull with the expectation I'd have to modify it for my QH. Turns out there was a procedure in the manual to reconfigure the upper "A" frame for QH adaptation...no other parts required. Works good too!
So, on this chilly day, might as well scan that manual...
/ Pat's Easy Change Vs Quick Hitch #70
Roy, Thank you very much. My Landpride manual doesn't have that info. After checking the Woods Brush Bull manual on line I see what you mean. Fortunately the Landpride has the same type of frame and it will be simple. Thanks again!
Did a little more reading and read where someone had posted that he had issues with his Cat 2 PEC fitting on Cat 1 implement with bushings due to the angle of the lift arms and that the width of Cat 1 being 26.5" and Cat 2 being 30.5" had his arms not "square" with implement pins. I do not currently have this issue I suppose due to the lift arm ball being able rotate.
Is this a legitimate concern? I had postponed this purchase for years to make sure I didn't invest in something I couldn't use. Clear enough explanation? Any thoughts? Worth stopping order?
Received the PEC Cat 2 for Christmas and got them installed this afternoon. Took a little longer than expected to install due to putting them on then pulling the lift arms in to the 26" spacing and having to readjust. When pulled in the PEC was leaning badly.
The parts I received did not match exactly as was shown on the instructions and there was no parts list. Wound up with four locknuts leftover that I couldn't see where they were supposed to go. Here are pics of the install. Those of you that have a PEC see anything I missed? I wound up using one shim, the largest sent, as it seemed to level up as needed. Was no instruction stating how they work, however they are simple enough to figure out easy enough.
your extra nuts should be on the side bolts to act as jamb nuts. the lock nuts go on the u bolts.
The diagram with the parts showed two nuts on each leg of the u-bolt for a total of 8. The diagram showed the side bolts as if were a piece of all thread, no cap/head for wrench, yet nothing like that was provided and there were four cap screws that fit the threaded holes. There were only four lock nuts so didn't seem logical that they were for the u-bolts.
The diagram with the parts showed two nuts on each leg of the u-bolt for a total of 8. The four locknuts would take care of that.
The diagram showed the side bolts as if were a piece of all thread, no cap/head for wrench, yet nothing like that was provided and there were eight cap screws that fit the threaded holes. Are you stating the nuts should be installed on the cap screw prior to running them in then once snug run the nut back against the PEC as a jamb nut?
/ Pat's Easy Change Vs Quick Hitch #76
IIRC, I used the lock nuts on the U-bolts and I did use nuts to jam the side bolts. BTW, my Pat's EC came with Allen type set screws...not hex bolts. Those bolts stick out way too far....
The instructions showed Allen type set screws as you mentioned. Maybe this is something new they are going to or trying. Think I will disassemble again and use the locknuts on the u-bolts and use the eight nuts on the set screws. May email PEC to make sure that is the intent so to not have to break it down but one more time.
Had tractor out doing some loader work and backed up to disc harrow just to see how easy it would connect. It is as easy as described. Adjusted the stabilizer bar a little and think I am good to go. Look forward to trying it on my other implements.
/ Pat's Easy Change Vs Quick Hitch #80
Any one with the quick hitch that need to get the bushings from cat 1 to cat 3 size go to the Northern Tool site and order them on line they are way less. A set of these bushings at TSC are like $32 and on Northern they are only $12.99 you have to pay shipping but even with that they are like $21 or $22 still less and if you get more than one set the shipping gets better. Now if you are lucky enough to have a Northern by you your even better off. Here is the link.
http://www.northerntool.com/images/product/200x200/508/508700_200x200.jpg
