Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #521
Stillhunter....did you buy the standard ones (102) and if so, did they fit the lift arms ok?? I also have a NH tc33d and I am worried that the distance to where the arm bends is too short. TIA
Sorry for the delay. At the time a couple years ago I think I bought the standard one. Not sure if there was a choice at the time. Mine fit fine
   / Pat's Easy Change System - Order Online! #522
Interested in Pats QH, but not sure which to get. Can anyone tell me if Cat 1 or Cat 2 would fit better on a Kubota MX5100? Or what are the key dimensions for fit?
   / Pat's Easy Change System - Order Online! #523
Is the arms Cat 1 or Cat 2 on your tractor?
   / Pat's Easy Change System - Order Online! #524
i am only farmilar with chinese tractor, and the implements for the chinese tractors. :)
   / Pat's Easy Change System - Order Online! #525
   / Pat's Easy Change System - Order Online! #526
They are Cat 2, but can be used with Cat 1 using bushings.
The same in our case and that is why I ordered the Cat 2 to Cat 2 to have Pat's heavier hitch. I bush up to Cat 2 on some equipment.
   / Pat's Easy Change System - Order Online! #527
Did Pat ever answer the questions about the binding that is created when the ball at the end of the lift arms can't allow rotation because the 4 bolts are tightened down? The problem was created when sideways movement of the implement required rotation on the balls at the end of the arms. I understand you can tighten the sway bars/ chains but that creates other problems. I saw the question asked a few times but never saw an answer. I think those asking the question were going leave the 4 bolts out or loose. Is that a problem?
   / Pat's Easy Change System - Order Online! #528
Are you out there Pat?
   / Pat's Easy Change System - Order Online! #529
What implement are you using that needs to swing side to side enough to cause this problem?
   / Pat's Easy Change System - Order Online! #530
I ended up not tightening down the two side bolts and left the U bolt loose so the Pat's setup can still swivel on the ball on the end of the arm. So far no issues. Prior I was seeing a little binding when using my boom flail mower (like they use for side of the road maintenance) and the boom sees resistance. That was resulting in the 3 point pivoting away from the boom side and binding. I am not seeing why doing it this way would be a problem.
2018 Toro Reel Master 5510-D Fairway Reel Commercial Mower (A56857)
2018 Toro Reel...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58216)
2018 MQ POWER...
2371 (A58376)
2371 (A58376)
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
