Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #521
Stillhunter....did you buy the standard ones (102) and if so, did they fit the lift arms ok?? I also have a NH tc33d and I am worried that the distance to where the arm bends is too short. TIA
Sorry for the delay. At the time a couple years ago I think I bought the standard one. Not sure if there was a choice at the time. Mine fit fine
   / Pat's Easy Change System - Order Online! #522
Interested in Pats QH, but not sure which to get. Can anyone tell me if Cat 1 or Cat 2 would fit better on a Kubota MX5100? Or what are the key dimensions for fit?
   / Pat's Easy Change System - Order Online! #523
Is the arms Cat 1 or Cat 2 on your tractor?
   / Pat's Easy Change System - Order Online! #524
i am only farmilar with chinese tractor, and the implements for the chinese tractors. :)
   / Pat's Easy Change System - Order Online! #525
   / Pat's Easy Change System - Order Online! #526
They are Cat 2, but can be used with Cat 1 using bushings.
The same in our case and that is why I ordered the Cat 2 to Cat 2 to have Pat's heavier hitch. I bush up to Cat 2 on some equipment.
   / Pat's Easy Change System - Order Online! #527
Did Pat ever answer the questions about the binding that is created when the ball at the end of the lift arms can't allow rotation because the 4 bolts are tightened down? The problem was created when sideways movement of the implement required rotation on the balls at the end of the arms. I understand you can tighten the sway bars/ chains but that creates other problems. I saw the question asked a few times but never saw an answer. I think those asking the question were going leave the 4 bolts out or loose. Is that a problem?
   / Pat's Easy Change System - Order Online! #528
Are you out there Pat?
   / Pat's Easy Change System - Order Online! #529
What implement are you using that needs to swing side to side enough to cause this problem?
   / Pat's Easy Change System - Order Online! #530
I ended up not tightening down the two side bolts and left the U bolt loose so the Pat's setup can still swivel on the ball on the end of the arm. So far no issues. Prior I was seeing a little binding when using my boom flail mower (like they use for side of the road maintenance) and the boom sees resistance. That was resulting in the 3 point pivoting away from the boom side and binding. I am not seeing why doing it this way would be a problem.
Hatz Diesel 6 Inch Water Pump (A57453)
Hatz Diesel 6 Inch...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A57453)
2016 Hino 195h...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
8 Piece Excavator Heavy Duty Attachment Set (New/Unused) To Fit CAT 301 (A59225)
8 Piece Excavator...
2000 Club Car DS Golf Cart (A57453)
2000 Club Car DS...
