Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #441
The economy hitch is not surface-finished to the same standard
as the grey coloured one that I bought and they supply the washers too.
Pat'S Quick Hitch Cat 1, Stabilizer Bar Included
Are Agrisupply still getting through the old stock style ?
   / Pat's Easy Change System - Order Online! #442
Here is a photo of what AgiSupply sent me. Other than color, I see that the grey one has a rounded base as opposed to a cut-angle. So I guess there is a difference, but ....
   / Pat's Easy Change System - Order Online! #443
With some tool and die backgound they do NOT look equal to me.
   / Pat's Easy Change System - Order Online! #444
i thought i'd drop in a post a note about the easy change system i purchased early in the spring...
i switched from finish mower to the dreaded bush hogger yesterday... that's the ONE toughest change i make. the bush hog is so heavy and i can never seem to back into the thing right, and end up doing a lot of pushing and tugging. it was so easy yesterday, that a caveman (me) did it! the only thing that would have made it easier would be if someone else hitched up for me. i got off the tractor twice, once to make sure the spacing was correct, and once to hook up the PTO shaft and upper arm. no pain no strain...
see y'all!
   / Pat's Easy Change System - Order Online! #445
Bought my Pat's on line here and have been using it over a month now. Wow!, what a difference in hooking up.
I changed between a land leveler, a brush hog, and a weight box in 5 hours, (busy ya know) and it was easy as
all get out. Now, get more washers and I will be set....Once you have it leveled out on your arms, all you have to do
is move the arms out slightly to adjust for different widths of equipment, usually between 0 to 4 inches and then good
to go.
Thanks Pat.
Tom
   / Pat's Easy Change System - Order Online! #446
I have a question about whether the Easy Change System will fit on my tractor. I have a Kubota L3800. I read in the TBN store that the straight portion of the lift arms need to be approximately 4 inches long for the Easy Change to fit properly. I just measured the straight portions of the lift arms on my tractor and found they measure approximately 3.5 inches long. Does anyone know whether they will fit my lift arms? Thanks very much.
   / Pat's Easy Change System - Order Online! #448
They'll fit your hitch . Just took this photo . Notice the measurements and compare with your actual ; quite standard .
   / Pat's Easy Change System - Order Online! #449
Hi OrangeRidge,
Thanks for the photo! I just measured from the front of the link hole to the start of the bend in my lift arms. I have the same dimension you have on your tractor, 2.5 inches. I also remeasured the straight portion of the lift arms and I have approximately 3.5 inches. I will place an order this week.
BTW - I intend to use them to hook up to my 5' bush hog. The PTO shaft looks like I will have plenty of adjustment. May need a longer top link. Will know when I install the hitches. Do you hook up to a bush hog, if so how do they work for you?
   / Pat's Easy Change System - Order Online! #450
The extra length of the arms require a few inches of twisting added to the top link , and your propshaft will be too short ( mine was .... ) probably.
1202 (A58374)
1202 (A58374)
2023 CATERPILLAR 259D3 SKID STEER (A52709)
2023 CATERPILLAR...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
1454 (A57192)
1454 (A57192)
New Bolt on Receiver (A59000)
New Bolt on...
2006 Dodge Ram 1500 (A56858)
2006 Dodge Ram...
