Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #701
I've had great luck with Pat's, on both my tractors. Yeah, you need to check the tightness of the bolts periodically.
I'll continue using them. Certainly makes hookup easier.
   / Pat's Easy Change System - Order Online! #702
a regular quick hitch is tons easier to use that the Pats, and you don't have to get off the tractor to use it
   / Pat's Easy Change System - Order Online! #703
   / Pat's Easy Change System - Order Online! #704
Agreed. They both have their good and bad points, you just have to decide which you would sooner deal with. I don't have the "pat's" but I have my home made version that worked exactly the same. The part I didn't like was having to play around with the spreader bar for the lift arms. It was a pain and I still had to get off the tractor to attach the top link. I bought a QH and have been happy ever since. Everyones opinion and needs are different, hence the reason for different designs. Both the pat's and the standard QH are great systems and make impliment hook ups easier, I just like the QH better.
   / Pat's Easy Change System - Order Online! #705
Dang. I just learned that Pat's has discontinued the "Slide-In" model.
I was excited about getting a set of them. :.(
Price dropped for Black Friday to $144.95 on the cat 1 standard and similar discounts on all other models. We will run this price through Tuesday. Price will go up next year for sure, we've been told.
   / Pat's Easy Change System - Order Online! #707
Is it possible to purchase replacement springs for this hitch? I got my hitch a couple of years ago and have busted both springs. Thanks!
   / Pat's Easy Change System - Order Online! #708
I broke springs twice, call them up and let them know. I got mine for free but that was a while ago...
   / Pat's Easy Change System - Order Online! #711
I sure will. I sent an inquiry, and honestly, I'm happy to pay for a few springs. I like using the hitch, but it's pretty sloppy without the springs.
   / Pat's Easy Change System - Order Online! #712
Well, I’m very sorry to report that as of yet I have heard nothing from my inquiry. I left my email and cell number, as per required on their contact form. It’s really pretty discouraging that as a customer that has purchased from these folks, they won’t reply to a simple question of how I might purchase replacement springs. That is NOT good customer service.
   / Pat's Easy Change System - Order Online! #713
I went to their online chat box last night and again asked if I could purchase replacement springs. Left my name and contact information as no one was actually manning the supposed online chat. So far…. Crickets.
   / Pat's Easy Change System - Order Online! #714
Which website did you go to for the chat? Problem is there are so many places selling it now,
If you are using the TBN site, most likely not going to work
I remembered the name. This is the site I called/emailed was named after the original "Greenwell Manufacturing" This: greenwellmfg
If not give this a try...
Customer Service — PAT'S QUICK HITCH at least there is a phone number here...
   / Pat's Easy Change System - Order Online! #716
keep us posted
   / Pat's Easy Change System - Order Online! #717
It worked! I used your link to get Sherry and she took care of me right away. I ordered two sets of springs so I have a pair in reserve. They indicated the springs would go out tomorrow. 👍
   / Pat's Easy Change System - Order Online! #718
Good deal... Did they charge you?
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
JLG 2630ES ELECTRIC SCISSOR LIFT (A60429)
JLG 2630ES...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
