Pat's Easy Change Pat's Easy Change System - Order Online!
/ Pat's Easy Change System - Order Online! #681
Wow, that was quick. Thanks.
Also a bit of good news about it raising the PHD higher. I was going to have to adjust my PHD because it raises just high enough to clear the ground. Hitting a bump causes it to drag the ground.
I have a PHD project coming up in early Summer and will give it a try/post the results.
Thanks, again.
/ Pat's Easy Change System - Order Online! #682
The new TL came in and I've tried it out. Looks like it is going to work.
Thanks for all the assistance.
/ Pat's Easy Change System - Order Online! #683
Glad you got it sorted out. My Massey has fairly long 3pt lift arms because it's a utility machine, and I also needed an extra long top link when I tried to use Pat's on it (I removed them and put them on my LS). For this sort of situation, the weld on version of Pat's would be better. Cut the ball off the lift arms, weld on the Pat's and the finished length would be fairly close to the original. That's one of the projects I have planned for one of these days....
/ Pat's Easy Change System - Order Online! #684
Update - The new toplink is working well. Adding Pat's to my tractor may be one of the best things I've done. I no longer give a second thought to changing implements.
I never found changing implements difficult but did find it time-consuming. Multiple on/off the tractor, extending lift arms (which never seemed to be happy unless all the way in or all the way out, no happy middle). Alabama is hot. Changing an implement in the summer always resulted in sweating thru my shirt. This is just much easier.
I'll probably be adding them to my JD as well.
Thanks to all.
/ Pat's Easy Change System - Order Online! #685
Got the new pats easy change and picked up the 6 spline adapter from tractor supply. My question is what did you use to hold adapter on a bolt and nut or roll PIN.
thanks Ron
/ Pat's Easy Change System - Order Online! #686
thanks Ron
You first have to have a hole in your tractor's PTO spline. There are adapters made with the push pin type of connector but AgriSupply stopped carrying them.
eBay has some for around $23. Search for "PTO adapter".
Here is another source:
Double HH Quick Release PTO Adapter Extender at Blain's Farm & Fleet
If you do have a hole, use a bolt. There will be some applications where the adapters are not needed and a bolt is easier to remove.
/ Pat's Easy Change System - Order Online! #687
Needed to dig some holes recently. Post hole digger worked fine with the Pat's Easy Change.
Best part of having the Pat's is that I now am more likely to change implements because it is so easy.
I'm getting a lot more done.
/ Pat's Easy Change System - Order Online! #688
Yep, that's the bottom line...easier changes mean you change when you need to, not when you feel like it, and you can get more done in the same amount of time.
Reminds me I need to order a weld-on set of Pat's for my Massey.
/ Pat's Easy Change System - Order Online! #689
Thanks gwdixon found one @ the local farm and home $34 but no shipping and fits great
/ Pat's Easy Change System - Order Online! #690
Re: Pat\'s Easy Change System - Order Online!
Anyone else using Pat's on their Kubota L series tractors?
Im not sure I have them setup correctly. They seem to be angled in a bit too much. But maybe its just because of how the lower arms made....
/ Pat's Easy Change System - Order Online! #692
I bought a set of Pat's easy change attachments about 4 years ago. They have spent the last 3 or so years laying in the shop as scrap iron. Best money I spent was for a 3pt quick hitch and then modifying the things I use the most often to fit that. A **** of a lot easier to use.
/ Pat's Easy Change System - Order Online! #693
I threw a set of pats away about a month ago after they had been sitting in one of the out buildings floor for several years. Kept stumping my toe on the blasted things. Tried them and didn’t like the way they worked so went to quick hitch and never looked back.
/ Pat's Easy Change System - Order Online! #694
I threw a set of pats away about a month ago after they had been sitting in one of the out buildings floor for several years. Kept stumping my toe on the blasted things. Tried them and didn稚 like the way they worked so went to quick hitch and never looked back.
I used mine for awhile, but decided they were far more trouble than they were worth. They most likely would be ok for a hobby farmer on an acreage who uses his tractor for light duty occasionally, but for someone like me who farms and really uses his tractor, they weren't worth a bum rap. Hooking up was a time consuming event that was best done with a 2nd person present. Also the bolts that hold the couplers in alignment won't tolerate much with heavy or hard usage. They wouldn't stay tight due to the bolts mushrooming under hard usage. This made the removal a real pain in the rectum. After I FINALLY managed to get the bolts backed out so I could remove the couplers, I tossed them in the corner. I'd considered using grade 8 bolts, but decided that could really cause some problems, so I also went to a quick hitch and never looked back also.
/ Pat's Easy Change System - Order Online! #695
Grade 5 bolts work fine with the Pat's, and they can be readily drilled out (LH bits preferred) if they should ever break off.
I like my Pat's Easy Change, but then too I only do play with my equipment.
/ Pat's Easy Change System - Order Online! #696
My grade 5 bolts mushroomed bad enough it allowed the couplers to be loose on the 3pt arms and move around. I had one heck of a time backing them out to get the adapters off the arms. Having to drill them out would be a real pain. For serious work a quick hitch is the only answer.
/ Pat's Easy Change System - Order Online! #697
Your grade 5 bolts?
The Pat's is shipped with grade 2 bolts.
Are you indicating that you had already replaced the manufacturers grade 2 bolts with grade 5?
/ Pat's Easy Change System - Order Online! #698
Your grade 5 bolts?
No, they were the stock bolts, I mistyped. I thought about putting in harder bolts, but had so much trouble getting the originals out, so I could remove the adapters, I decided against using harder bolts. If they'd of twisted off, it would have created a real mess. Drilling them out would have been a real pain, and would have taken up some real time. Most likely that would have resulted in screwing up the threaded holes in the adapters as one would have had to use a drill bit about as big as the bolt as trying to remove them with an easy out would have been an effort in futility. A true quick hitch was the solution. Easier to hook up and a lot quicker.
/ Pat's Easy Change System - Order Online! #699
WOW just WOW.
Back to the drawing board???
/ Pat's Easy Change System - Order Online! #700
WOW just WOW.
They used to have weld on one's available, maybe still do. A good blacksmith could install those. That would cure the bolt problem if you were able to install them at the proper angle. The only problem might be crystallization of the metal, from the welding heat, which might fail under very hard usage. But for light or normal usage they would most likely be more than adequate and wouldn't be such an eyesore as the others. Plus you may be able to install them in a way that wouldn't result in the 4" lengthening of the arms that can result in needing a longer top link. Just a thought for the acreage boys.
(38) 8" - 11'L X 20" - 34" FLOOR TRUSSES (A60432)
(38) 8" - 11'L X...
UNUSED IRANCH IRLMB HYD MINI CONCRETE MIXING BKT (A60432)
UNUSED IRANCH...
FORD 4600 TRACTOR (A60430)
FORD 4600 TRACTOR...
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
UNUSED ZJG ZJ-12 EXCAVATOR (A60430)
UNUSED ZJG ZJ-12...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
