part missing
/ part missing #1
budgeary
glocester, ri
ford 3510
The attached picture shows a 3/4'' threaded hole where something is missing on my 83' 1520 ford diesel tractor under the throttle pedal. Anyone know what's suppose to be there? A plug? breather port??
/ part missing #2
Mount for a step?
/ part missing #5
G'day I would say it's a level plug for the trans.
You might want to check the other loader frame bolts in the first pic looks like they might be a bit loose.
Jon
/ part missing #6
I'd have to agree with banjodunn, looks like a fill hole for the trans.
/ part missing #7
Looks from the pics like this is the bell housing area, it would be a dry area, no liquids
/ part missing #8
Na, the bell housing is further left of that hole, you can see the bolts to the engine.
/ part missing #9
Strange - entering the model number AH4137 (plate in picture) gives no results in new holand parts look up. I like a mystery and per the parts diagram listed above the hole goes into the clutch case. Maybe an inspection hole? Might be worth a call to a NH dealer.
However you can also check with the folks on this forum Antique Tractors - Yesterday's Tractors : Parts and Online Community under Ford. They were a great help on my 503 rake.
Hope this helps
/ part missing #10
I would ask Soundguy, he is the most knowledgeable person I know on all things Ford Tractor
/ part missing #11
I PMed him, maybe he can weigh in
/ part missing
I was miss informed, the tractor year is a 1990. and the hole is beside the clutch pedal not the throttle pedal.
/ part missing #13
Bellhousing area, so dry. Straight bolt thread or pipe?
Never owned a 1520... 90's are kinda new machines :)
If it had been a bigger hop with rubber plug I'd maybee have said a port for getting a grease gun tube in there for greasable bearings.
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
Tailgate Mulcher Portable Hay Blower (A65579)
Tailgate Mulcher...
New/Unused Fuel Delivery Tank with Pump (A65583)
New/Unused Fuel...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
