part missing
/ part missing #1
budgeary
glocester, ri
ford 3510
The attached picture shows a 3/4'' threaded hole where something is missing on my 83' 1520 ford diesel tractor under the throttle pedal. Anyone know what's suppose to be there? A plug? breather port??
/ part missing #2
Mount for a step?
/ part missing #5
G'day I would say it's a level plug for the trans.
You might want to check the other loader frame bolts in the first pic looks like they might be a bit loose.
Jon
/ part missing #6
I'd have to agree with banjodunn, looks like a fill hole for the trans.
/ part missing #7
Looks from the pics like this is the bell housing area, it would be a dry area, no liquids
/ part missing #8
Na, the bell housing is further left of that hole, you can see the bolts to the engine.
/ part missing #9
Strange - entering the model number AH4137 (plate in picture) gives no results in new holand parts look up. I like a mystery and per the parts diagram listed above the hole goes into the clutch case. Maybe an inspection hole? Might be worth a call to a NH dealer.
However you can also check with the folks on this forum Antique Tractors - Yesterday's Tractors : Parts and Online Community under Ford. They were a great help on my 503 rake.
Hope this helps
/ part missing #10
I would ask Soundguy, he is the most knowledgeable person I know on all things Ford Tractor
/ part missing #11
I PMed him, maybe he can weigh in
/ part missing
I was miss informed, the tractor year is a 1990. and the hole is beside the clutch pedal not the throttle pedal.
/ part missing #13
Bellhousing area, so dry. Straight bolt thread or pipe?
Never owned a 1520... 90's are kinda new machines :)
If it had been a bigger hop with rubber plug I'd maybee have said a port for getting a grease gun tube in there for greasable bearings.
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
Fertilizer Openers (A65640)
Fertilizer Openers...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
