Pallet racks; outbuilding structure?
/ Pallet racks; outbuilding structure? #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
I recently bought some pallet racks at a very decent price. I was thinking of using them as a framework for an outbuilding for storing my implements. The racks are heavy-duty, 12' high and I have 12' long cross pieces; the racks are 3' 6" deep. My plan was to bolt the upright frames to PT beams that would sit on cement tubes. I bought 4 sets such that I would have a 2-bay area building that was 24' wide and 10' deep (if I set the two racks 3 feet apart) I Planned on utilizing the shelf on the back rack so that I could put lighter implements on the shelf while allowing room underneath to park additional implements.
I planned on making a sloped shed-style roof with 2x8's resting on the racks cross-ties set lower on the uprights front to back and covering it with metal roofing. The uprights would be sawz-alled flush with the roof framing.
For siding I planned to attach 2x4's horizontally to the metal cross-ties and uprights and then I would attach barn-board and battens vertically to the 2x4's.
I know this sounds a little unorthadox, but do you think it's possible? Do you think a building permit would be required? Do you think an inspector would grant one based on that design?
/ Pallet racks; outbuilding structure? #2
Sounds like an excellent design to me.
I've worked with a lot of pallet racking and seen some pretty extreme abuse, so I don't think you need to worry about strength & rigidity.
As for permits...That all depends on your local rules. Be very polite to all concerned & you might get lucky. A friendly AND smart inspector can be your best friend.
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A65643)
2005 DRAGON 130...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
