Forks Pallet Forks...
/ Pallet Forks... #1
JimMorrissey
Southern Maine (now)
'05/'06 L39 TLB
Does anybody have a set that's roughly 70" wide and 40" long (quick-attach)? My dimensions are probably off, but something close is OK.
Who made them?
What did they cost?
Build quality?
Have you seen better set for less money.
/ Pallet Forks... #2
Jim,
Sounds as you're looking for something already built, but if you can find a set of forks with the mast off an old F/L you might "roll your own". This picture shows what we did to make a set to match my MF quick attach. It's 6' wide, and I believe the tines are 42".
/ Pallet Forks... #3
I have a set of QA Bobcat forks 48" long for my Woods 1016 loader. You can vary the width up to about 48", would have to measure to be sure. The forks are solid with way more capacity than my tractor/loader has. I've lifted a known wieght(2k) of block. They make forks much heavier than what I have as well, very stout. They were under $700 a year ago.
/ Pallet Forks... #4
I have a pretty good set and I think the company is Katsco if I remember correctly. I always use them set at 48" but they are adjustable wider. Picked them up from a New Holland dealer and they have served us very well.
They are QA by the way.
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2017 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2017 FORD F150...
213063 (A64276)
213063 (A64276)
2002 12ft Haulmark KD7X16WT2 Cargo T/A Enclosed Air Cascade Trailer (A66738)
2002 12ft Haulmark...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2016 Toyota Camry Sedan (A66738)
2016 Toyota Camry...
