Pallet Forks
/ Pallet Forks #1
Magnum3252
Potsdam, NY
2017 JD 1025R
Which ones should I buy folks? I have a JD 1025R. Thinking about the Titan forks
/ Pallet Forks #2
I have these from Titan and like them:
Titan 48" Pallet Fork Attachment Skid Steer Universal HD Pro Duty Tractor Loader
You would probably need the JD version though. Just wait for a sale though. They run different sales all the time, sometimes as much as 15% off. If you're looking at the style I linked above make sure you also price out the ones that come with the bale spears. When I got mine the one with the bale spears was on a special discount and was also on a holiday promo. I got the set I linked above WITH the bale spears for about $360.
/ Pallet Forks #3
I have these 30" clamp on forks by Titan. Easy on, easy off. Very handy. Well made.
Titan 3" LW Clamp on Pallet Fork 15 lbs Capacity Loader Bucket Skidsteer Tractor: Amazon.com: Industrial & Scientific
/ Pallet Forks #4
I have the fixed 46" titan forks. I don't know how I lived life without them. Look them up, crazy cheap to get your feet wet. (Think I paid $260 shipped)
Edit: oops you have JD...mine is ssqa.
/ Pallet Forks #5
I have the 42" Titan forks and love them, use them all the time. I also second the motion on getting the bale spear, comes in very handy.
/ Pallet Forks #6
1, Do you have SSQA or the JD equivalent?
2. Is your present bucket fairly strong?
3. What's your perceived usage?
If you have a QA then a QA solution makes sense,
/edit unless $$ are tight
If you don't clamp ons are good if you have a strong bucket, but I've seen some that may get bent with clamp ons. I've 2 tractors that I use Titan clamp ons with, but I have only very occasional usage.
I you are going to be using them frequently and wanting to switch to other FEL attachments then clamp ons don't make much sense.
I really like my clamp ons, and have occasionally put all 4 on my M4700, but then I don't have SSQA yet. Another slight advantage of clamp ons is they take up little space when removed.
/ Pallet Forks #8
I got these from titan (on sale now) Titan 46" Pallet Fork Attachment Skid Steer Quick tach Mount 26 lb Capacity
use them for soooo many things -pulled a truck bed, moved swingset, w/ a pallet on them as a man lift for tree trimming, lumber and log moving, brush pile moving, and i fyou look at the link above you'll see the a chain slot - so I use them for pulling posts out of the ground.
I plan to mount my snow blade to to the plate for winter use.
/ Pallet Forks #9
Just make sure you get 48 inch forks. Dont get the shorter ones. They limit you.
/ Pallet Forks #10
+1 for the above post for a minimum 48” fork length. I would have preferred 60” but they didn’t offer them with the 6500lb rating.
/ Pallet Forks #11
If your tractor can only lift 4100 lbs why pay for forks (cost, weight to lift/carry reduce lift capacity) that are 50% mroe than that?
/ Pallet Forks #12
/ Pallet Forks #13
Price difference was $38 for the heavier set, so that wasn’t that big of a difference for a heavier fork. I don’t see the weight differences in the actual forks to compare and besides I like the back rack design on these compared to everything else. The rack is high to allow for more support when you tilt the load back and the design has the forks mounted back so that the front side of the forks is flush with the front side of the upper rack which gives a solid support top to bottom for your load. These were the only ones I seen like that.
Plus I like Teds videos!!
But you are right, if 1800lbs was the limit on my front end loader, a few hundred lbs would quickly make a difference!
/ Pallet Forks #14
I got the Titan 42" forks some years ago. Never once had the thought, wish they were longer/bigger. Depends on what you do. I got the short forks to make moving around among our trees and bushes a bit easier.
/ Pallet Forks #16
If using a fork blade to pry or lift with one fork at or near tip , fork quality makes a big difference.
Technically forks are designed for an evenly distributed load across the length. However life throws us challenges so we all use the tools we have as best we can at the time.
/ Pallet Forks #18
You don't say what you plan to do with them. I bought a set of the Titans because they are affordable, and find them very handy. However, for some things such as piling logs the narrow width can be frustrating; balancing a 27 foot tree can be frustrating and time consuming. I also managed to bend the backing plate when I caught a tine under a rock while lifting.
/ Pallet Forks #20
I had 42 inch forks and a 48 in two post bale spike so I went with 60inch adjustable forks and they are the best for me love the reach
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2021 Ford F-150 Pickup Truck (A61573)
2021 Ford F-150...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
