Pallet Forks
/ Pallet Forks #1
Sfrankland
Newfoundland
Mahindra 5010 Cab, Kubota U35-4
Started out with a set of clamp on forks that I built but wanted a proper set. Sold my clamp on ones and bought a set of used forks that came off an electric forklift.
First thing I had to do was weld a tube to the back of the forks so they could pivot and slide on the support rail. The forks are 1 1/2" thick and needed to be preheated on the wood stove with the draft open to get them plenty hot. Not sure how hot they got but after 6 hours with the draft wide open I couldn't pick them up with heavy welding gloves on.
Next job was to lay out the frame and clamp it down to the what will soon be the new top to my welding table. The two ends and center support were drill on the mill and machined to 1.28" in diameter.
Frame all welded up.
Picture of a few of the welds on the frame.
Another picture of the welds.
Start of the guard. I ran out of steel so I will have to finish it up latter.
SSQA plates welded on to the frame. Getting ready to add the forks.
Some more welds
Frontal shot. My son still hasn't stacked up the wood yet. It Christmas so I have given him a few days to get it done.
Forks installed.
Lifting the table and 1/2" steel plate. Total weight is around 375Lbs. Lots of capacity left in it yet.
Need to machine up some end caps to keep the rod from sliding. There will be 4 altogether, one on each side of he end supports. Also you can see the gap between the top of the forks and the frame. This will allow the forks to be able move a bit in case they are not positioned right entering or exiting a load.
Mounted on the tractor.
Decided to add some D-rings one each end and will add two more on the bottom tube so I can wrap a chain around a load if need be.
That is all for now. Will post a few more pictures once I get it all done.
/ Pallet Forks #2
Wow, you have some excellent fab skills! Looks like a great match to your Mahindra. :thumbsup:
/ Pallet Forks #3
Nicely done! You should get many hours of use from those.
/ Pallet Forks #4
Very nice indeed; wish I could do stuff like that.
/ Pallet Forks #5
Very nice job. I think they are nicer than ones you purchase anywhere.
/ Pallet Forks
Finally got them all done a painted. Very pleased with now they turned out.
/ Pallet Forks #8
Well Done! Any idea what they weigh in at?
/ Pallet Forks #9
Nice looking job.Well thought out and fabbed.I like the D ring idea and will add them to my fork lift frame.
/ Pallet Forks
No idea. I need to find a set of scales to weigh a project I have coming up. If I manage a set I plan on weighing them. If I was to guess I would put them between 200-250lbs.
/ Pallet Forks
I added the chain hooks to the bottom as well I figured I could wrap a chain around a load if need be. I moved some very large stumps last fall and the chain hooks and the forks themselves would of come in really handy.
/ Pallet Forks #12
Did you create SSQA on your bucket too? I like that idea. All my stuff is pin on.
My forks are Kodiak, similar to the ones on Northern Tool. I think they are TOO heavy, at about 350lbs. But they pin on front or rear, and are very handy.
/ Pallet Forks #13
I made this weight for my 3 point hitch. It works well I think.
/ Pallet Forks
When I started looking for a blade for snow clearing I decided I wanted a SSQA. I looked around for one but no one made one so I had to build it myself. Cutting a perfectly good bucket was hard but I have no regrets now that it is done. The forks themselves make up 3/4 of the weight. They are 1 1/2" thick and can be man handled but I wouldn't want to carry them to far.
I am looking a building something like this now. I normally have the backhoe on in the summer and the snowblower is on now but I find it is hard to work in tight spots because of the overall length.
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2009 Infiniti FX35 Multipurpose Vehicle (MPV), VIN # JNRAS18W09M158535 (A64557)
2009 Infiniti FX35...
300 Gal Portable Fuel Tank w/Pump (A64127)
300 Gal Portable...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
Giyi XKH39 Mini 4-in-1 Bucket (A64126)
Giyi XKH39 Mini...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
