Pallet Forks/Markham/JD
/ Pallet Forks/Markham/JD #1
dmccarty
Super Star Member
Triangle Of North Carolina
JD 4700
Has anyone bought the Markham Pallet Forks? I have searched TBN and I see people talking about getting the forks but I have not seen anyone who has actually purchased.
Markham is near enough to me that I can travel to pick up the forks. I would prefer pallet forks that attach to the bucket but it looks like Markham's product cost less and does more....
I could not find a price on pallet forks from JD or anyone else. Markham is asking $530 for a unit that can handle 3,900 pounds. Is this a fair price. It sure is compared to the bucket forks.
Later,
Dan
/ Pallet Forks/Markham/JD #2
The bang for the buck on the Marham forks you mentioned seems very good.
I just bought a set of light duty Payne's Forks for $290 including shipping. They work as advertised. I like the fact that each fork weighs 35lbs so I can easily move them by hand. Since I don't need to pick up very heavy loads these were the best for me.
Rich
Rich,
I was comparing Markham's product with Payne's and Markhams looks like a better deal. I have numerous cubes of bricks to move at our house site. The best I can figure they weigh between 1700-2000 pounds. We ordered extra for a garage that will be ordered later and the builder over ordered as well. It only costs $100 per cube so I would rather have more than less..... /forums/images/graemlins/grin.gif
For what it would cost to pay someone to move the cubes I bet I could buy the forks and move them at the same or close to same price..
We also will be buying new appliances and it will be nice to be able to off load them with pallet forks on the tractor. I have lots of pallets at the house site and I'm going to use them to store firewood.
I thinking about puting the pallets in the back of my pickup. Loading stuff from the house onto the pallets and tieing them down. Once I get out to the property I can off load the pallets from the truck to the porch which will make things a whole lot easier....
Melissa at Markham's said the forks work with JD 400 loaders so I should be good to go.
Later,
Dan
/ Pallet Forks/Markham/JD #4
Dan,
You mentioned alot of used for the forks but one that caught my eye was the movement and storage of firewood. I will be doing the same when I get a moment. I was going to use pallets and chicken wire or snowfence to keep the wood on the pallet. But then I noticed crates at the local floor tile store. The crates are pallets with sides. Perfect for wood. Unfortunately the crates I saw were sitting outside too long to be worthwhile but now that I know they exist I'll find a few.
Rich
/ Pallet Forks/Markham/JD #5
</font><font color="blue" class="small">( I have numerous cubes of bricks to move at our house site. The best I can figure they weigh between 1700-2000 pounds. )</font>
Last time I looked, a pallet of bricks was closer to 3,500 lbs but it may only have been the particular ones I was looking at.
Since my JD855 will only lift about 750 lbs on the forks, it's not an issue for me.
</font><font color="blue" class="small">( We also will be buying new appliances and it will be nice to be able to off load them with pallet forks on the tractor. )</font>
They're very useful for that. The last delivery, I parked the tractor in the driveway so I could respond to the truck quicker, particularly as he must stop in the road. The driver said it made it really easy to figure out which house he was delivering to. /forums/images/graemlins/cool.gif
/ Pallet Forks/Markham/JD #6
Dan,
If you go to Denton, NC, maybe you could stop at Piranha Attachments, link attached. Their prices seem very good and I was wondering about their quality. Hope you give us a report.
John
Piranha Attachments
/ Pallet Forks/Markham/JD #7
Bricks or stone on a pallet can add up to over 3500 or even 4500 lbs quickly for a typical pallet "cube". Most of the smaller to medium CUT's are not going to be able to lift that much weight.
Still, its a lot less work to re-stack the stone or bricks into 1/2 or 1/3 cube units so they can be easily moved around than to move the whole pile a few bricks at a time or one wheelbarrow at a time.
One thing to notice on the lift curves is that a lot of machines can lift more lbs down low than they can to full height. For example, at the ground, my 4100 can lift maybe 1200 lbs. At full height, its rated for only 800lbs or so. Those weights are with the bucket. I built my forks to be as light as possible, so I maybe get another 100 lbs over that rating.
This is actually really helpful with the forks since you generally are not lifting things to full height. Usually just a few inches to get ground clearance, or at most, up to a truck bed.
I find that I hit the max lift capacity of my little 4100 a lot more often with the forks than with the bucket digging dirt.
Be sure and check your front tire pressure and ratings before lifting anything like 4000 lbs!
For anything at all heavy, I would recommend that you will want forks that replace the bucket.
Even with the stock bucket attach on my 4100, switching is not a big deal. Jump off, pull the pins, dump the bucket, get in drive up to the forks, jump off, and replace the pins, jump on and start moving stuff.
- Rick
/ Pallet Forks/Markham/JD #8
I bought a set of quick attach pallet forks for my Kubota L3130 from markham welding two weeks ago. I promptly made use of them moving a 1000# round bale of hay and removing a few downed trees from last weeks tropical storm. They are a nice markham attachment to have. I believe they were $425. plus shipping.
/ Pallet Forks/Markham/JD #9
Hello Dan,
I am in NC and a local JD dealer quoted me $968 for a set of forks for my 430 FEL. That is a steep premium to pay for something that isn't even green.... I am thinking about an alternative at 1/2 the cost.
/ Pallet Forks/Markham/JD #10
Hi,
I bought a set of Markham forks this summer. They work fine. They slide along the rails for any spacing or lock in place at 3 different spacings. What I really like is that they are easy to take apart and store flat, along the shed wall, out of the way. I will use them for a few days and then store them for a couple months. I have not seen forks I like any better for any price.
David
Currmudgeon,
The builder and I where going over the weight of the brick cubes. They are roughtly 2.5'x2'x3' so at 150 pounds a cf we figured about 2,250 pounds. I found a brochure from one brick company and it listed some numbers. I came up with about 1800 pounds per pallet depending on the brick. My 460 can lift just shy of a 2000 pounds but that is full height so I should be able to move them.
In a couple of weeks we will find out if I'm right! /forums/images/graemlins/grin.gif
Later,
Dan
jmc,
I did not see prices for the forks but Piranha's look just like Markhams. I'm pretty sure I'll be getting the Markhams at $530 but I don't think I can get down there until next week.
So far Markham has been a pleasure to deal with. Melissa Markham has a good sense of humour.
I asked her if I could get the forks in the back of my truck. This is what she said., "Yes these forks will fit into the bed of a pick-up, we have even loaded them into the back of a mini-van- the wife wasn't to happy but the husband was ecstatic. Please let me know if we can help."
Sounds like the man was a TBNer! LOL! /forums/images/graemlins/grin.gif
Later,
Dan
dbrauner,
I was thinking that I heard the JD forks costs around $1,000. The Markhams sound good.
Later,
Dan
/ Pallet Forks/Markham/JD #14
</font><font color="blue" class="small">( I asked her if I could get the forks in the back of my truck. This is what she said., "Yes these forks will fit into the bed of a pick-up, we have even loaded them into the back of a mini-van- the wife wasn't to happy but the husband was ecstatic. Please let me know if we can help.")</font>
Just brought home a 5' box blade in my wife's minivan 2 days ago - good thing she didn't see me unloading it with the FEL (a pretty delicate operation using the FEL less thank 6" from the liftgate...).
/ Pallet Forks/Markham/JD #15
Piranha's are $450. Good luck.
John
/ Pallet Forks/Markham/JD #16
Hi again Dan,
The most I can pick up on my forks with my tractor (no weight in the rear) is 1200#. That would be a pallet loaded slightly biased toward the tractor. Anything you lift is quite a ways in front of the tractor causing a large leverage problem. To lift 2000# on the forks will require a lot of weight on the rear, even more than a backhoe I will guess. I figure it takes 3# on the back o my tractor for each additional 1# I would add on the front over my 1200# limit.
Best wishes,
David
/ Pallet Forks/Markham/JD #17
I sent them an e-mail. I understand that the JD FEL's have their own quick connect system so I really want one that fits the JD bucket.
/ Pallet Forks/Markham/JD #18
</font><font color="blue" class="small">( I built my forks to be as light as possible, so I maybe get another 100 lbs over that rating. )</font>
OTOH, the center of mass of your load is most likely to be farther forward with forks. So the lift arms are working at a mechanical disadventage, and can probably lift less.
You also have a greater overturning moment when using forks, so the danger of tipping over is greater.
/ Pallet Forks/Markham/JD #19
To throw anoter $0.001 worth in , unlimited I got some stuff from this place and they were very responsive. They are also in Denton, NC.
/ Pallet Forks/Markham/JD #20
Try BRADCO just bought a set for $800 and love them. Best built forks I have seen, including the Deere. (cant believe I said that)
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
