Pallet Fork Frame Dimension
/ Pallet Fork Frame Dimension #1
lostcause
Maine
Picked up a pair of forks at the scrapyard nearly a decade ago for $30, and finally got a tractor with a quick attach and enough lift capacity to make use of them, so I bought a frame and the forks won't fit - they are really close but too tight to slide across the frame. Looks like the frame dimensions I found on the internet are 16" between top and bottom plates, and mine are all of 16-3/16". What's the norm on other fork frames? I'm assuming I need to take some metal off of the frame, but I also want to make sure the forms aren't a little snug too.
/ Pallet Fork Frame Dimension #2
Went out and measured mine. Right at 16"
/ Pallet Fork Frame Dimension #3
I just always made them (or HORST DID, long ago) to fit the forks I had, regardless of dimensions.
/ Pallet Fork Frame Dimension #4
I bought a universal blank 3/8" thick steel welded off ebay for $94 shipped to build/attach my pallet forks. Got 1 1/8" solid round to go through the top, and angle iron welded to the bottom. Total cost was under $200. Make sure whatever you do it's adjustable side to side. I've put these through the ringer time and time again, haven't flinched. My bobcat tips at 1000lbs though, if you're on a bigger tractor you can probably do more.
Mostly just trying to see if the frame was fat or whether the forks were snug. Probably safe to assume it’s the frame. Obviously mismatched brands but I was assuming some standardization. Guess I’ll have to grind off about 1/8” and see how free the movement feels
/ Pallet Fork Frame Dimension #6
I think you are on the right track. I think my forks are standard. They measure almost 16 - 3/8 inside dimensions. I built my rails with 16 inch spacing and all is well.
/ Pallet Fork Frame Dimension #7
The standard for class 2 fork tines is 16” spacing.
I guess mine grew on the slow boat over from China. not a huge deal I guess. just a little quality time with a grinder this weekend. The tines need a little scuffing down anyways.
Hedge Posts (A65640)
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2001 Sterling Single Axle Dump Truck SELLING OFFSITE (A62613)
2001 Sterling...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
