Owning/operating
/ Owning/operating #1
CBOYDS
MF135
Need some help I have a 1971 MF 135 diesel I changed the fuel filter and now I can’t get it primed back to start up .
/ Owning/operating #2
Is there a hand pump?
Did you fill the fuel filter with fuel (I don’t recommend this, but have done it from time to time)?
/ Owning/operating #3
Did you crack the lines at the injectors, and bleed the air? I know that's the intent of the hand pump, but I think you still need to bleed the air?
/ Owning/operating
Yes I have fuel at the injector & the filter is full it always cranks on the first turnover
/ Owning/operating #5
Disconnect a fuel line near the tank to be sure you get good flow from the tank. Sometimes there's crud buildup which prevents fuel from flowing freely. After ensuring good flow bleed the air from the system normally.
/ Owning/operating #6
Leave the lines loose for a while at the injectors while cranking. You may still have air pockets in the line and it doesn't push through.
/ Owning/operating #7
It takes a lot longer to clear out the air than it seems like it should.
/ Owning/operating #8
You might have some crud in your fuel lines . . . if you have a string trimmer take a few feet of the line and run it threw your fuel lines to clean the crud out.
/ Owning/operating #9
On a 71 Massey 135, once I knew I had fuel to the pump and any squirting out of an injectors line, if it doesn't fire right off I'd just tow start it.
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A65643)
2013 POLAR TANK...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
