Owning HP wakeup call
/ Owning HP wakeup call #21
4 Vehicles. Jeep, Ram, and two beaters with heaters.......737 hp
MX 5100......................................................................51 hp
Mini ex ........................................................................40 hp
ZTR .............................................................................27 hp
SXS .............................................................................54 hp
Logsplitter .....................................................................16.5 hp
3 kids ATV's ....................................................................36 hp
9 chainsaws.....................................................................39 hp
Total.............................................................................1000.5 HP
Looks like I "just" made the 1000hp club.
Would have been a little higher about 3-4 years ago. Sold the ~85hp backhoe for the 40hp mini, sold a ~50hp ATV. And traded the wifes 5.7 hemi ram 345hp in for the 172hp jeep.
And At one time I had a 116hp motorcycle and a ~580hp Firebird
But if we throw on some electric HP, I have a 10hp compressor, 10hp lathe, 5 hp lathe, and 2hp knee mill that could add another 27hp :ROFLMAO:
/ Owning HP wakeup call #22
Yeah I was thinking the log splitter, chainsaws, pole saw, spin trim, riding and push mowers are worth some Horses as well.
/ Owning HP wakeup call #24
Pretty strange thread IMO.
Well, you could start one about who has the most "Tractor" horsepower.
You and Hay Dude would be near the top I would think.?.
Down Under member
MBTRAC might take honors overall.?
Try adding up the cost of fuel you have used over your lifetime. Now look at how many tons of carbon you've dumped into the atmosphere.
I added it up for my 3/4 ton crew cab 6.6L V8 turbo diesel 6.5 foot box 4x4. I was averaging 14,000+ lbs of CO2 per year driving a 10,000 lb truck with an empty bed more than half the time.
Great job, that's less than Mary Ng created on her flight to Davos this year.
If chainsaws count a 10 hp lathe has to count!
/ Owning HP wakeup call #29
My wife's SUV has more horsepower and better power to weight ratio than my 86 5.0 liter Mustang had:
86 Mustang 5.0 - 200 hp 265 ft. lbs. - 3000 lbs.
19 Edge ST 2.7 TT - 335 hp 380 ft. lbs. - 4477 lbs.
I'm about 100 hp short of 1000 right now.
Kevin
/ Owning HP wakeup call #30
2013 Impala LS is 300hp 3555# = 0.084 power to weight ratio
86 Mustang 5.0 - 200 hp 265 ft. lbs. - 3000 lbs. = 0.066 power to weight ratio
19 Edge ST 2.7 TT - 335 hp 380 ft. lbs. - 4477 lbs. = 0.074 power to weight ratio
It's kinda fun to plug in numbers and see what you get....
/ Owning HP wakeup call #31
Surprised the Impala torque is 262 lb-ft @ 5,300 rpm
Any grease monkeys care to explain that? Are all three ratings at the fly wheel?
These are the 0-60 and 1/4 mile numbers I found:
13 Impala SS - 0-60 - 6.3 sec, 1/4 mile - 14.7 sec.
86 Mustang LX 0-60 - 6.3 sec, 1/4 mile - 14.7 sec. (I saw a different torque rating of 285 lb-ft)
19 Edge ST 0 - 60 - 5.7 sec, 1/4 mile - 14.3 sec.
/ Owning HP wakeup call #32
Gosh, if I owned just one Tesla model S plaid, I could be in that 1000HP category.
Tesla model S, plaid, 1020HP, 960ft-lbs of torque.
Supposedly, it hits peak HP at 80mph, and keeps it to 200mph. Nearly linear torque from 0mph up.
My wife test drove a co-worker's model S once. She came home and was still floating from the high. Muttered something about doing zero to 80 to zero in a (deserted) city block...:eek::devilish::eek::ROFLMAO:
I don't think that we will ever hit the collective 1,000HP mark; not enough serious work here.
All the best,
Peter
/ Owning HP wakeup call #33
Explain what part? The Impala torque number?
Or the fact that the mustang with the worst HP/weight tied the Impala with the best?
Or that the edge beat them both with the hp/torque in the middle?
I can't explain the Impala torque number because I don't know what you are asking about it.
But the drag times and 0-60 is more than just peak HP and weight. It's a lot about hearing and also what's called "area-under-the-curve".
Peak HP just that. The highest HP it can produce at a given rpm. But no 0-60 or 1/4 mile run remains at a constant rpm.
So what's the HP at all the RPM ranges it will see (area under the curve).
And I'm guessing the edge has like a 9 or 10 speed trans to keep the in the peak power zone better.
/ Owning HP wakeup call #34
There was no Impala SS made in 2013. They stopped in 2009.
/ Owning HP wakeup call #36
LS then... what are the major mechanical differences that cause an engine to have considerably more torque than horsepower and visa versa? Stroke length, cam profile, both, or other things?
/ Owning HP wakeup call #37
YES! :ROFLMAO:
Bore
Stroke
Compression ratio
Cam
Timing
Fuel systems (carbs, EFI, Direct Injection)
Turbos/superchargers
You can take two engines that have the same displacement, but very different bores and strokes. The longer stroke engine will likely have more torque at lower RPMs and the shorter stroke engine will be able to rev faster.
All kinds of stuff in there.
/ Owning HP wakeup call #38
Interesting article. I had one FWD muscle car and I'd never have another. Had a Pontiac SSE and the torque steer under hard acceleration was almost uncontrollable. Went like a raped ape but keeping it between the lines was another issue.
/ Owning HP wakeup call #39
These are some posts I pulled from past discussions when comparing V8 to L6 engines. People were saying the L6 made more torque than the V8 of same displacement. It wasn't accurate.
We've talked about this before. A straight six and a V8. The V8 will produce more HP and Torque than the straight 6 of equal/near equal displacement. However, the straight 6 will produce it's torque at a lower RPM, giving the 'feel' that it's more powerful, even though it's not.
I think the discussion was based on the ford 300 straight 6 vs the ford 302 v8, and similarly, the Chevy 292 vs small block chevy's.
And then this:
Here’s some interesting comparisons of the V8-302 and L6-300.
The 302 always made more HP and more torque than the 300.
However, the L6 made it’s peak torque at a lower RPM, hence it felt like it pulled sooner, because it did pull sooner. That’s why it felt better for launching a loaded pickup.
/ Owning HP wakeup call #40
2017 Mustang 5.0 GT making 450 horsepower to weight ratio 0.1286
2011 Porsche 3.4 making 349 hp to weight ratio 0.1396
1965 Cobra replica 5.0 making 320 hp to weight ratio 0.1600
Ford diesel 3.2 making 197 hp to weight ratio 0.0563
MX5200 Kubota making 52 hp to weight ratio 0.01156
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2010 BMW 128i Convertible Coupe. (A61574)
2010 BMW 128i...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
