Overheating Information
/ Overheating Information #21
He's still around. Post made this month, just not about Yanmars. He still reads, I imagine.
/ Overheating Information #22
California showed the same thermometer i got. I think i paid like 12.99 on sale? Does that sound right Cali?
That HF Infrared Thermometer photo I linked above has a laser pointer to show a red dot where you are measuring.
I have HF's simplest 'Non-Contact Pocket Thermometer', same thing but smaller and no laser dot, it just measures whatever in front of it. It was $9.99 at HF's Parking Lot Sale.
Anything that works like this will be fine.
/ Overheating Information #23
Yea hes still on TBN not the yanny forum. I saw o post in the attachement forum or somewhere the other day he made in a thread i posted in as well.
/ Overheating Information #24
my temp light came on twice this year. cleaned the grass seed out of the rediator each time & the light went off. Now that I've got the loader. Maybe the bucket will catch all or most of the grass seed. Another reason to get the loader:D
/ Overheating Information #25
I think that is wishful thinking. I make a point to stop and clean mine every 15-45mins depending on the type stuff im in longer if it is clean each time.
/ Overheating Information #26
Interesting that 70/30 is suggested for high temps.
In my world average day time temps are 95+ from June to Sept (SW FL). In my LIQUID cooled engines most (non diesel) all recommend a 50/50 glycol water mix. These engines are in relatively high performance motor cycles (100 HP 900 CC) and V8 trucks. If you try to run more water say 70 water versus 30 glycol you will overheat the engine.
If you read the small print on a jug of your favorite antifreeze (glycol) you'll find that the highest boiling point is for a 50/50 mix. Point is that if it doesn't boil out it will still cool the engine. So I'm at a loss as to why and higher water mix would work better in higher temps in a diesel tractor.
Terry
/ Overheating Information #27
Terry
Well I'm sure someone more knowledgable will chime in but it's my understanding that the 70/30 mix is the optimum for the thermosiphon cooling system. It's this percentage mixture that is good for max circulation and cooling. I'm not all that scientific but the yannie engineers say it works and so do many others. YMMV......
/ Overheating Information #28
Maybe but the Yanmar service manual I have (YM276) says to use a "Permanent" type ethylene glycol anti-freeze. If you read the label on the jug of same it says 50/50. I've never seen a Permanent type anti-freeze coolant that wasn't 50/50 but maybe there is something else around, and I do live in a pretty hot area.
Terry
/ Overheating Information #30
Should point out also that the 70/30 recommendation is for the models that DO NOT have waterpumps. Those are the models which survive on the thermosiphon system. Believe I'm correct on this......
/ Overheating Information #31
Thanks Winston for posting the link. Interesting but my 2310 has a water pump and pressurized cooling system. I would agree with the original poster that a clean and functioning cooling system should not have an issue with a 70/30 mix. Keeping in mind that that is water to glycol. That mix would give you a temp range (from freezing to boiling) of -34f to 265f. The 50/50 mix is -84 to +276. You don't get 100% glycol in the typical jug of antifreeze. A 50/50 mix of the typical jug with water will get you the 70 water to 30 glycol mixture.
Terry
/ Overheating Information #32
Terry
Where did you get the temperature range for a 70/30 mix? My information says that will freeze above zero degrees F.
Ethylene Glycol Heat-Transfer Fluid
/ Overheating Information #33
I compared the boiling and freezing numbers quoted on the back of a Prestone antifreeze 50/50 mix bottle to the numbers on the website you gave.
Prestone 50/50: freezing -34 F/boiling 265 F
Website 50/50: freezing -36 F/boiling 225 F
I just found a Peak antifreeze bottle, and it matches the Prestone bottle. The freezing numbers are close, but the boiling points are way off. The "Engineeringtoolbox" website has a very authoritative name, but I guess this is a reminder that we shouldn't believe everything we read on the internet. :)
This is a good warning that the 30/70 mix will not for people like me because it will freeze at about 0 degrees F. Have to remember to change it...
/ Overheating Information #35
Interesting. The boiling point is related to pressure. I wonder if the manufacturer is referring to a pressurized radiator and the website is referring to an open vessel. We all know modern engines can operate at higher temps than 225 without boiling over. The temp sensor in our Yanmars is set for 238, as I recall.
/ Overheating Information #36
I stand corrected. The numbers I gave where for a 50/50 antifreeze mixture and a 70/30 mixture.
Terry
/ Overheating Information #37
Ah, but it's the things we don't read that get us. The writing on the Peak and Prestone bottles indicate that these figures are with a pressurized radiator with a ~15psi cap. The 225 degree figure is with atmospheric pressure. That website is giving the specs on the antifreeze solution all by itself. :)
Good point! Increasing pressure at low temperature would also increase the freezing point BUT lucky for us, when it's cold it's not pressurized.
So do our Yanmars' cooling systems pressurize? I think the answer is yes... :confused:
/ Overheating Information #38
Sure. I think Yanmar's spec (Metric) is 13-something psi and a 14 psi cap spec'd for 70's Datsun is the easiest replacement.
I like the lever-release style radiator caps, they seem safer.
Comment - this isn't rocket science, especially the two cylinder Yanmars. These are just one generation evolved beyond open-tub cooling reservoir like a 1920's stationary engine. (well maybe overstated a little. :D)
For lubricants use modern diesel-rated stuff, for everything else the first stab at finding generic service parts should be 70's Datsun (or Subaru, Honda, etc) including the oil filter, radiator cap, oil and temp sensors, etc. Yanmar designed these early ones to be supportable in all corners of the world and used generic parts for a lot of the maintenance items. The air filter is the only unique design among maintenance parts that I have encountered. Oh and the headlights - shared only with some brand of snowmobiles (Yamaha??) as I recall.
/ Overheating Information #39
One other factor that may be at play here is the specific heat of the different solutions of antifreeze. Water has a very high specific heat-it holds a lot of energy compared to other materials. The ethylene glycol in antifreeze holds less energy at a specific temperature than water does.
Using high concentrations of antifreeze raises the boiling point and lowers the freezing point, but it's deceptive, since it takes less energy to get the solution up to that temperature. It takes a larger volume of antifreeze solution to absorb a set amount of heat than it does straight water. That extra capacity to hold heat may keep localized boiling in hot spots, and better keep the radiator cap from boiling over.
/ Overheating Information #40
I have heard it said that "even rocket science isn't rocket science anymore." :D Even so, with all the this talk of specific heats, pressure induced changes in phase transition temperatures, etc. it's a bit more science-ee than we usually get. :thumbsup:
Cultivator (A62613)
Cultivator (A62613)
2004 Peterbilt (A62679)
2004 Peterbilt...
2000 Chevrolet 1500 Conversion Van (A66408)
2000 Chevrolet...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
2012 PETERBILT 386 (INOPERABLE) (A65643)
2012 PETERBILT 386...
