Overheating BX2000...
/ Overheating BX2000... #1
bferster
Middleburg, VA
Kubota BX2200
I have a Kubota BX2000, and after 1/2 hour of running, it overheats.
I've cleaned the filters, radiator and grill with an air hose and there's plenty of coolant.
Some of the threads suggest the thermometer. Where is it, and is it hard to replace? I live 30 miles from the nearest dealer.
Thanks!
Bill
/ Overheating BX2000... #2
Thermostat... And it's usually situated at the water outlet on the head.. or very nearby.
Try a flow test on your radiator.. ( a good flushing might help it anyway )
Put your outlet hose into a 5g bucket, and stick a garden hose in your filler neck.. turn water on.. a good radiator should be able to keep up with the flow and drain into the bucket.
Soundguy
Soundguy
/ Overheating BX2000... #3
Make sure you clean behind the radiator (fan is reverse air flow). Hard to see behind it but can clog up very bad.
mark
Thanks for the tips.
I flushed the radiator (the water ran out just fine).
Really cleaned the radiator.
Replaced the thermostat.
Still it overheats after 1/2 hour.
Any other ideas?
Thanks!
Bill
/ Overheating BX2000... #5
Sounds like you covered most everything. Can we assume that you tested the temp with a thermometer in the radiator neck to confirm the gauge/sending unit is good?
I guess that just leaves the water pump as a possible culprit. Is the water pump easy to replace, or is this a dealer thing?
Thanks!
Bill
/ Overheating BX2000... #7
After all you have done, the pump should be easy. Real easy if you remove the radiator.
Make sure you get all the old gasket off the block.
/ Overheating BX2000... #8
See if you can test the water pump.. it's a very simple type of pump... they suck from the bottom of the radiator.. taking the top hose out and aiming to a bucket with thermostat out should tell you if there is flow..
Soundguy
Club Car Emergency Cart (A64557)
Club Car Emergency...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
1457 (A65054)
1457 (A65054)
2020 Takeuchi TL10V2 Compact Track Loader Skid Steer (A66734)
2020 Takeuchi...
2004 FRAC TANK 500BBL WHEELED (A68842)
2004 FRAC TANK...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
