Outdoor Lamp with a Light Sensor
/ Outdoor Lamp with a Light Sensor #1
jlgurr
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
We've put up a lamp post by our sidewalk and would like to install a light sensor on it. This way it can be on only during dark hours. I've seen flood lights that come with the sensors but can I buy a small one and install it for use in this sort of application?
Thanks,
jeff
Thank you Newbury! I just got back from there and got just what I needed. Wife will VERY pleased with this purchase.
Thanks again,
Jeff
/ Outdoor Lamp with a Light Sensor #4
Just keep in mind that many CFL and some LED lights do not work with the photo eye.
I switched to the Connected by TCP programmable LED lights. I can choose when they go on an off, turn them on and off with my iPhone, dim them, etc. A little pricey up front but i calculated a 2 year payback over an incandescent with a photo eye. Search Results for connected by tcp at The Home Depot
Downside is you do need wifi at your house and the lights need to be in range for the smart gateway.
/ Outdoor Lamp with a Light Sensor #5
I haven't had any issues with the stand-alone photo eye switch and anything that's been run down stream of it. They cost somewhere between 10 and 15 bucks, and ours has been working flawlessly for 8+ years.
/ Outdoor Lamp with a Light Sensor #6
I have several working with CFL bulbs, outside and inside. Only problem I've run into is if I converted to LED. Many of the devices kinda leave a tad of current going, and that tad ignites LEDs so that they never go off.
We recently bought a new sensor switch in our family room to accommodate our LED bulbs (can get ones that are tons brighter than CFLs for our old eyes). Told them we wanted one with a manual switch for when we stay in the room. Paid about $30 for it. Well, the manual switch STILL works off the **** timer that turns the lights off after a certain time if no movement is seen. So, we have to raise an arm or leg to turn them back on.
Ralph
/ Outdoor Lamp with a Light Sensor #7
I suppose it depends on what technology the light sensor uses,, but I have never had a problem using any kind of bulb either. Usually the cheaper sensors I use are bi-metallic sensors.
They have a light sensitive resistor inside them(photo resistor). This resistor controls the current to a heating element that is wrapped around a bi-metallic arm with a contact on it. When the photo-resistor see's light, it's resistance is low, and the heating element gets hotter and the bi-metallic arm bends and pulls the main lighting contact up and breaks the circuit to the lights. This is why when you first hook the system up and the sensor has not been powered, the lights will come on even in the daytime for a minute or two, it is waiting for the bi-metallic arm to warm up and bend.
At night the photo resistance is high, the heating element cools, and the arm bends back down and the contacts touch, making the circuit. And this system naturally gives you some delay in the system also, which is desirable to keep the lights from blinking on and off if something temp blocks the sensor.
Very simple reliable and cheap. If you mount the sensor directly below your pole light, there is a chance the light from the top of the pole will be "seen" by the sensor. This will cut the light on and off continually all night long. If this happens, you can sometimes place a short tube or eyebrow over the sensor to help shield it from the light above.
