MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,332
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Just remember that that output of the hydraulic PTO on a PT425 is only about 12HP.A few more thoughts came to mind.
In the case of something like the Grillo, the tractor itself is most likely designed around a certain width for tillage and with a certain HP in mind. The Grillo salesman recommended a 28" flail as matching well to the available HP in part because a wider flail demands more power than a rotary cutter and stalling the unit can damage the clutch. Wider isn't always better if it becomes too much for the power unit.
The Bachtold has a 26" single blade if I remember while the Gravely brush deck is 30 inches. The Orec Cyclone cutting width is 25.6. These seem to be representative cutting widths for walk behind brush cutters.
Coming back to my experience, clearing a 24" or 30" path typically means I will get stuck by briars that overhang into the path. It would be better, IMO, if they'd make brush cutters with about a 48" cut because you'd have a wider path cleared plus the acres mowed per hour should be double that of a 24" cutter assuming the same level of cutting performance.
48" happens to be the cutting width of the PT425 rotary brush cutter driven by a 25 gas engine.
2500psi@8GPM = 11.67hp
That being said, it would be a lot faster than the walk behinds. I typically make two passes for our trails with about a 1' overlap so 7' wide. Plenty of room for two people to walk next to each other.
It will absolutely destroy anything in its path. My wife mentioned many years ago how small everything gets chopped up once run over by the brush cutter.
There are issues with the brush cutter. If you hit a hidden rock, or repeatedly hit rocks, it can break the bolt head off and you can lose a blade. It takes a bit of work to get the broken bolt out, but many of us have come up with good solutions for that. It is very easy to work on yourself. Most of us keep spare bolts and blade bushings on hand, and an air impact wrench and sockets really make it go fast.
The forward/reverse treadles on the PT425 on the left and right feet make it very easy to control and vary speed from 0 to 8mph in both directions. So when you get into heavy stuff, just slow down to appropriately comfortable speed.
As mentioned, my only concerns would be the steepness of you slopes, and that's why I'd recommend a test ride with the implement you want to use in conditions similar to yours before deciding on a purchase.
