A few more thoughts came to mind.
In the case of something like the Grillo, the tractor itself is most likely designed around a certain width for tillage and with a certain HP in mind.  The Grillo salesman recommended a 28" flail as matching well to the available HP in part because a wider flail demands more power than a rotary cutter and stalling the unit can damage the clutch.   Wider isn't always better if it becomes too much for the power unit.
The Bachtold has a 26" single blade if I remember while the Gravely brush deck is 30 inches.  The Orec Cyclone cutting width is 25.6.  These seem to be representative cutting widths for walk behind brush cutters.
Coming back to my experience, clearing a 24" or 30" path typically means I will get stuck by briars that overhang into the path.  It would be better, IMO, if they'd make brush cutters with about a 48" cut because you'd have a wider path cleared plus the acres mowed per hour should be double that of a 24" cutter assuming the same level of cutting performance.
48" happens to be the cutting width of the PT425 rotary brush cutter driven by a 25 gas engine.
