order issues with Everything Attachments, hope I'm wrong
   / order issues with Everything Attachments, hope I'm wrong #41
EA may not be the fastest to respond to a problem but they usually do everything they can to rectify the problem. Glad to see it worked out.
Follow up: Some had asked for me to report on how I liked the plugger/aerator. I like it very much. It took me just over an hour to do my one acre property. First time and it was a learning experience. Some things I learned, first I'm glad I got the 36" wide unit as it allows me to make shallow turns. Don't try and turn to sharply or the unit will tear up your yard. Yes, the 650 lbs weight is needed. It travels well behind the tractor. The unit is exceptionally well built and the easily replaceable spoons are strong. It is well worth the money. As an aside while the BX 25 may have been strong enough to use it , I'm glad I upgraded to the B series. Yes, you do need either weights up front or your front loader on for counter balance.... and be careful of fences, I slowly ran into my chain link one time with the front loader, it sticks out there( missed all the poles, thank goodness) but as I said it was a learning experience and I learned a lot. Definitely a worthwhile investment having property with a clay base.
   / order issues with Everything Attachments, hope I'm wrong #43
All I can say about EA is while deployed I ordered three items; a skid steer conversion for the loader on my Kubota L5450, a plate to wled to the bucket and a set of fork lift forks. All were delivered as promised and were wonderful quality. Because of this I do plan to order from them again.
   / order issues with Everything Attachments, hope I'm wrong #44
Where can I find a cutting edge, wear strip for a Kioti 401 72 inch bucket?
You can't get one. It's a 'throw away' tractor..............I'll be right over to pick it up.
Please send directions.
   / order issues with Everything Attachments, hope I'm wrong #45
This thread has ended exactly the way I expected.
EA going above and beyond to make things right :thumbsup:
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
Steel Tire Rack (A57454)
Steel Tire Rack...
(7) Ten Hole 25 Inch Steel Rims (A57454)
(7) Ten Hole 25...
