Orangeburg Sewer Pipe problem
/ Orangeburg Sewer Pipe problem #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
My 1957 home has about 250' of Orangeburg underground sewer line... for those not familiar, it is basically rolled tar paper that became very popular during the post WWII building boom and 50 years is about the max service life in a best case... so I am on borrowed time.
Has anyone tried to pull new sections of ABS line through the old pipe with a backhoe?
There is about a 65 foot section under my neighbor's patio/pool area... I have a 5' easement and later he had added the pool and and extensive patio... digging really is not an option.
Some of the local trenchless guys are very busy and the minimum price starts at $5,000 for a typical 40' run to the main... A homeowner paid 30k last year to upgrade his line or about $60 a foot.
County passed a new law this year requiring upgrades upon sale or large renovation so these guys have lots of work... All sewer lines must be inspected and certified... Orangeburg is an automatic fail.
Just out of curiosity, I looked into a turn key burst pipe rig and they price out at 30 to 40k...
It would be a lot easier to slide a 3" line in the old 4" Orangeburg... not sure this is an option...
Every three months I run my auger through the line to keep roots at bay... so my line is basically shot.
Any thoughts?
/ Orangeburg Sewer Pipe problem #2
I would wager that 4" has collapsed in places to be smaller than a 3 and would require digging. Perhaps your neighbor should have realized, or been reminded of, your easement before laying an expensive patio and pool on it.
I've not replaced any without trenching, as frankly I've never seen a sewer line installation worth the cost of trenchless tunneling. Perhaps your neighbor that poured the concrete on your easement would be interested in footing the bill for the trenchless driller?
/ Orangeburg Sewer Pipe problem #3
Negotiate with your neighbor for a new, unobstructed easement in trade for the old one.
Bruce
Both homes were built in 1957 by the same developer and each sit on one acre of some steep terrain.
Neighbor bought in 1957 and had Pool and Patio installed in 1964. I bought in 2005...
The HDPE pipe looks interesting... it is what the trechless guys use here in the city.
I'm really good at running my Sparton 300 drain auger... had lots of practice the last few years... there are other pathways that wouldn't effect neighbor and still provide ample slope... they would need me to saw cut and a lot more...
Years back, I watched a farmer pull pipe with a steel cable and an old backhoe... I found it fascinating that he made it look so easy
/ Orangeburg Sewer Pipe problem #5
I work for a civil engineering firm and am a land surveyor, but I have also done quite a bit of construction inspection. My experience is that the orangeburg pipe will no longer be round. It often ends up flat. If seen pipe bursting work well, but I don't know if it would work in your situation. I'd say you are stuck either open cutting it or going with a trenchless set up. Can you rent the equipment and do it your self. Some of the larger mini excavators can dig pretty deep.
/ Orangeburg Sewer Pipe problem #6
[...snip...] there are other pathways that wouldn't effect neighbor and still provide ample slope... they would need me to saw cut and a lot more...
Ultra, thanks for providing the info on dates... I think it pays to be a good neighbor, and though you have an easement, I commend your looking for a solution that leaves your neighbor OK, given the details and how long he's been there, etc.. I like the idea of looking for a new route for the drain... might simplify things a whole lot if you brainstorm on it for a while.
If you can test out the pipe pulling without a lot of cost, why not go ahead and do a "test pull", maybe just dragging a 3-inch section (just a few feet long) all the way through the drain underground... if it makes it through, good chance you could pull your own pipe. The only other problem I see with this is that a 3-inch drain seems awfully small (prone to clogging), and not sure if it would meet code (check locally). Remember if you do your math that the cross section of a 3-inch pipe is 7 square inches, and 4-inch is 12.5 square inches... that's a lot of difference (with regard to clogging).
Best of luck... this stuff isn't usually replaced until it ultimately fails. People all downtalk the Orangeburg, but it strikes me as kinda' funny: there's not much you can replace it with that you can expect to last as long... 50 years+ is a good long time!
So far... the few feet I have seen have not deformed too much... although, a local plumber says he always finds cross sections that look like a figure "8"... deformed top and bottom.
All the lines under the home are 3" cast iron and then transition to the 4" Orangeberg outside and under the added shop all the way to the main...
The drainage lines are also all Orangeberg... not really a problem so far.
I'm sure none of the line is deeper than 3 feet... there are two cleanouts and it is more like 24" deep.
The business next to work had trenchless work done... it was real slick... only two small 4'x4' by 4' deep pits to replace about 50' of line with a heat welded continuous High Density Polyethylene 4" pipe...
At least time is on my side... no plans to sell and I do have my auger at the ready...
/ Orangeburg Sewer Pipe problem #8
I have pulled 20' of 4" sch 40 through old OB. It worked pretty slick. One thing in your favor is that most of the time there has been enough leakage around the old OB that it makes it slicker to pull the new. I made a plug out of a 4" iron cap. I drilled a hole in it and put a HD eyebolt in it. It is just a little bigger than 4" sch 40. I threaded a 4" male PVC adapter into it and glued the pipe to it. I let it set for 24 hrs. Took the sewer tape and back pulled a cable. I took the trackhoe and it slid out the OB and pulled in the sch 40. 50-60' would be nerve racking.
There was a guy on the job last week with a boring machine. He bored in several hundred feet of pipe. Have you checked on having a new line bored in right next to your old one? With their sending unit they can hold it on grade and true R/L to within a few inches. Then you could pull in your own 4" sch 40.
Sounds very slick...
Just spoke with the supply house and they carry 20 and 40' lengths... depending on qty... price is between $2.50 and $3 a foot...
I'm in earthquake country and little tremors happen here... sometimes, ABS will break because it is not very flexible...
Like the pipe cap and eyebolt!
My neighbor has one of the large WARN winches... 12 or 15k... have no idea if that is enough pull.
You are right about seepage... every joint I've uncovered seeps.
/ Orangeburg Sewer Pipe problem #10
I'm no expert but dos'nt relining just conform to the inside of the existing pipe ? If the OB is oval shaped you would just end up with a new pvc oval pipe ? Or a new figure 8? Maybe they can run a slug through there to reshape it, like pipebursting ?
It would probably be worth it to televise it anyway. If you do a lot of your own maintenance I think you can get a low end camera pretty cheap - $ 2-3K ?
/ Orangeburg Sewer Pipe problem #11
Will 3 inch pipe pass code? Can you use ABS or does it have to be SDR?
The way I see it, you can dig the open trench for most of it, which makes it a simple do it yourself project. The section under your neighbors patio is where the challenge is located.
When I had my 6 inch water line installed under the State Highway, with permits, the labor was $3,000. I had to buy the 6 inch pipe and the 8 inch metal pipe that the six inch pipe goes into. They drilled the hole first. Then cut and bent over the metal pipe to create what looked like the tip of a bullet. They welded on an eye to the end of the metal pipe and attached a chain to it. Then they used a backhoe to pull that metal pipe through the hole. It went 100 feet just as easy as could be.
Seeing what they did, I wonder if the plastic will have enough strength to be pulled through the hole you have in place, and how you will attach your chain to it? Maybe run the chain all the way through the pipe and have it connceted to something at the end of it so it's pushing the entire pipe? Will the pipe crumble or break if you hit a tight spot? then what?
Can you use metal pipe for the drain in that area?
Can you bore or pull out the existing drain pipe?
Good luck,
Eddie
/ Orangeburg Sewer Pipe problem #13
you might look at a sewage ejector pump setup modern materials work well and would only require a 2" line which could go anywhere dug in only below frost line. look at set ups at orencosystems web sitestay with small dia chamber and there float and pump setup or equal
greg
/ Orangeburg Sewer Pipe problem #14
Seems to me the county has some blame in this matter if they required you to replace the line. This is when you became aware that They must have given your neighbor a permit to install the pool and if so how come they ok'ed it over your easement? planning dept must have been a sleep and that would make them responsible cause they caused an infringement denying you access to your easement. Of course you might find out that you no longer have an easement as your neighbor has blocked you over a long period of time? you might want to contact an attorney.
Appreciate all the replies...
My line/easement runs about 145' on my neighbors land... much more than is on my side.
We get along great... he's OK with whatever I want to do as long as when I'm done everything is back to the way it was.
Some of the ideas of bypass the run are very doable... just, the cost to establish and record a new easement isn't cheap in the big city...
The trenchless guys make it look so easy... I've seen several jobs done and it was just another day for these guys... mine should be much easier because there is no street excavation at all... everything runs down the back...
The trench-less guys use HEPE with a bursting head and cable...
No way to pull out the old orangeburg... it just crumbles if disturbed...
At least I have some time... and the sewer auger I bought has paid for itself many time now...
I'm thinking of just attacking it a section at a time...
/ Orangeburg Sewer Pipe problem #16
My thought was not to attack your neighbor but to go after your county and make them do and absorb the cost of the replacement sewer line or any other property line ajustments. Glad to hear that you have a good relationship with your neighbor.
/ Orangeburg Sewer Pipe problem #17
Don't tell my crews $60 a foot for drilling they will be there. We are paying $6.
Dont mess around get a real Directional drill crew in. Map it out with test holes and have them drill it in. IF it is rocky they may just use the exisitng pipe and drill it out and pull in new HDPE.
Got a couple of bids... 5 to 7k for the one day job or about $65 per foot for the low bid.
Also found a rental yard that rents turn-key rig for $500 a day.
Only thing I would have to buy is the pipe and couplings...
I'm thinking about doing it myself in the Spring.
It is amazing how much apparent profit there is and the new law here requires all clay, orangeburg and broken cast-iron laterals to be replaced when a property is sold...
Typical crew is 3 people... sometimes two.
Found a contractor by accident that wanted the job @ $45 a foot.
The job turned out well, even with the downpour in the middle.
The old Orangeburg was no match for the bursting head and inch by inch the new line went in...
Three man crew and each had a job to do... just as well I didn't end up trying to do it myself.
/ Orangeburg Sewer Pipe problem #20
Glad to hear you got it all taken care of, and for a reasonable price.
Eddie
