timbrehse
- Joined
- Aug 31, 2006
- Messages
- 82
It's common knowledge all these blowers are manufactured by Rad Technologies and except for the impeller gearing these blowers are essentially identical. Since Kobotas spec'd pto speed is 2500 rpm vs Masseys of 2000 rpm, different gearing is used by rad tech to achieve the proper impeller rpm for both manufacturers. The gear ratio used Massey blowers 2:1 reduction while Kubotas is approx 2.9:1 therefore taking an optimum impeller speed into account these units are not really interchangeable.
Optimum impeller speed for these blowers is between 900-1000 rpm and while going higher is ok, going lower than this can compromises efficiency. Taking your gc tractor as an example where the impeller speed for a "massey" blower would be exactly 1000 rpm, swapping out for the same Kubota blower drops your impeller rpm to 687. For the sprocket chain blowers this is an easy fix to increase impeller RPM by just replacing the sprockets, Rad uses sprockets H40B26 H40C13 for the Massey MF2360.
Cheers
Wow-I haven' checked this board in a while
Thanks for the info Jaylegger ...AND Part #'s - love it when people post part#'s !!!!
I'll look into swapping out the sprockets but I can't imagine I'd need to increase my impeller's RPM. I'm afraid if I do this BX 5450 will be throwing snow a ridiculous distance... like into my neighbor's driveway! I had no difficulty last season moving what fell. Sure, if I'd nose into a 4 or 5ft bank, I'd get a little diesel bogg but I don't let it pile up. If it starts getting deep, I'll go out half way thru the storm. I prefer doing it twice to fighting with snow way over the top of the blower. And I'm not out there setting snowblowing speed records either. As is, this Orange on Red, w/ the flapper@45deg, will toss some fairly wet stuff 30ft or more w/o complaint.
However I DO have a complaint....about the 'newly designed outside mounted skid shoes' Granted, I like to scrape down on the blacktop. It then melts off quickly which is key w/ a steep driveway. I figured going in I'd be replacing the leading edge after 2-3 seasons or so but the shoes - no matter how hi or low they're set.. they're going to SKID ....and after one season, they're toast.
I've been looking for something like this
but the slot centers are 2.25" on the BX5450 - this is 2.5"
I found a standard pr. - Kubota Pt# 77700-05889 w/ shipping will run $55.
Any one have a better alternative?
