Options for SSQA trailer mover (receiver hitch) ?
   / Options for SSQA trailer mover (receiver hitch) ?
Got it ground smooth and painted up last night while the weather was still warm. Looking forward to playing around with it soon.
   / Options for SSQA trailer mover (receiver hitch) ? #62
deezler, if that is on the 3pt, can you still use the hitch receiver? Looks like it would need an extra long shank for the ball mount. Jon
The picture your quoted is the backside of the adapter, where it mounts on the front-loader SSQA.
The 2" receiver sticks out a bit on the front side when it's mounted. With that said, I do still kinda want to get a long shank insert to increase my reach and visibility when using it.
   / Options for SSQA trailer mover (receiver hitch) ? #64
I understand the receiver is usable on the loader arms. But can you use the receiver when the plate is on the 3pt? And yes that plate would hinder me to see the ball mount when trying to hook up the trailer. Jon
   / Options for SSQA trailer mover (receiver hitch) ? #65
I dont know what the actual tractor end of your SSQA looks like but you could 'window' the middle of the plate to get better visibility for the initial hookup if the tractor side would allow visibility there. Once hooked up you really don't need to see it anymore.
But considering the lift force at the end of a typical bucket is far more than most small trailers' tongue weight, i would just run an extension in the hitch to get the visibility if you need it. I have a ~12-14" 2" drawbar extension i use in various ways that would fit the bill. Put another sloppy fitting bit of 2.5" square tube facing up somewhere else on there and you'd also have a 'storage spot' for it while using 3pt stuff. Or drill another hole closer to the other end of your receiver and just run the drawbar backwards when something is on the 3pt. Or just put it in a box on your tractor. 😜
The other thing is you could run a big drop drawbar in it.. seems counterintuitive but it's easier to tilt the attachment down and see the ball under it, then to get it so far out in front that you could see the ball over it. You could 'dump' the attachment down probably about 45 degrees and still be able to slide the ball into a coupler like that. You can curl it up to level once you're in.
Nice work btw! And nice looking VW back there also.
Thanks. I’m legit impressed with that spot/identification of my hooptie. Had a new Alltrack, but Carvana was quite insane for a bit - so i took the profit and grabbed this Jetta off Craigslist to daily. Been fun to mod for cheap, and the 5-cylinder is honestly a pretty nice engine (once it has 20 more hp).
I honestly never even contemplated trying to hitch this ssqa plate onto my rear 3-pt hitch. I don’t… think it’s really meant for that? Seems like you’d have to bolt pins on one side of the lower 3-pt arm connections or it would be floppy as heck. But i also dont have any other rear towing provisions, so now i am intrigued lol. You’d just need a long-shank ball-insert for the receiver to get it pinned in and still extending enough to he useable. (Or drill another pin hole in the receiver tube right by the back side?)
   / Options for SSQA trailer mover (receiver hitch) ? #68
Im a big fan of 5cyl intake noise! They're not fast fast but, fun enough! I had a buddy with a 5cyl Golf who TORE UP h-stock class at local autoX for a while.
Im a car guy for life and only been a tractor guy goin on 2 years, so far. :)
   / Options for SSQA trailer mover (receiver hitch) ? #69
   / Options for SSQA trailer mover (receiver hitch) ? #70
On the last picture from deezler showing the plate on his loader arms, do I see the attachment brackets for the top link and two eyes below for the 3 pt arms? Just wondering. Jon
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
Wanco Message Board (A56857)
Wanco Message...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2013 HINO 338 26FT BOX TRUCK (A59575)
2013 HINO 338 26FT...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
