Backhoe Operating JD 448 Backhoe
/ Operating JD 448 Backhoe #1
brandon1
Question? I have a 448 Backhoe on a 3320 JD tractor. I was told from someone that I should lift my front and rear tires off the ground when operating the Hoe. Is this the right thing to do, because my manual does not mention it at all. Does anyone have any input on this. Thanks
brandon1
/ Operating JD 448 Backhoe #2
I still haven't tracked down the 448 manual online.
Here is the blurb from the 48 manual:
Digging Position
CAUTION: Avoid serious injury or death: Check for buried electric cables or gas pipes before you dig.
AVOID SERIOUS INJURY OR DEATH: CHECK FOR BURIED ELECTRIC CABLES OR GAS PIPES BEFORE YOU DIG.
IMPORTANT: To help prevent damage to backhoe:
Raise tractor only with stabilizers.
Do not let backhoe bucket contact stabilizers.
1. Lower backhoe stabilizers (A), and loader bucket (B) to ground.
2. Adjust throttle. (See Operating Tractor, in this chapter.)
Yea, thats what it basically states in the 448 manual also. So I don't interpret that as lifting the wheels off the ground, unless they mean lower the stabilizers and bucket as far down as the controls will make them go, which would then make the wheels go off the ground. I guess its a little unclear. I guess I can call my dealer and get his input as well. Thanks for your answer!
brandon1
/ Operating JD 448 Backhoe #4
Hmmm....so in that blurb it says to lower them to the ground, but nothing about raising the tractor off the ground. It would seem to me, the common sense solution would be to have the tires on the ground, but to also have the rear stabilzers and the front bucket contacting the ground. Lower center of gravity, etc. I would vote for tires on ground and stabilizers firmly contacting the ground as well.
If someone did not tell me about lifting the wheels off the ground, I probably would never have questioned it at all. Thanks
brandon1
/ Operating JD 448 Backhoe #7
That's just a beautiful machine....
and what a Digger!
/forums/images/graemlins/laugh.gif
/ Operating JD 448 Backhoe #8
I like to lift the front wheels just barely off the ground and the same with the rear wheels. Alot of the time the most important thing is to be level. In alot of the digging I've done that means you've got the tractor leveled with the stabilizers. You get alot more rock back and forth when you leave the wheels all the way on the ground in the front and back. Having the bucket down and the stabilizers helps to eliminate that side to side sway.
Thanks for the tip, I'll give that a try!
/ Operating JD 448 Backhoe #10
I agree with cowboydoc. I always have both set of wheels off the ground when the tractor is level. If the ground is not level, I use the outriggers and the bucket to level the tractor accordingly.
Richard
/ Operating JD 448 Backhoe #11
I have been wondering...
Does that mean NOT to use the loader or NOT to use the backhoe to raise the tractor. It certainly means NOT To use one or the other...
My friend has a stinkin; Cub Cadet backhoe. The manual is easily 10 times better than mine! I will look at it to see if there are any clues (I doubt it!)
/ Operating JD 448 Backhoe #12
Hi
I believe that when the manual says to only use the stabilizers to raise the tractor, my interpertation is that it is referring to the back end of the tractor only. It is frowning on using the hoe itself, i.e. bucket and dipperstick to do the job of the stabilizers.
I have been using the stabilizers to raise the back and the loader to raise the front for about 300 hours of backhoe work and have had no problems.
Richard
One thing that I think is clear, the manual is NOT very clear. They could have been more specific. Just my opinion.
brandon1
/ Operating JD 448 Backhoe #14
<font color="green"> One thing that I think is clear, the manual is NOT very clear </font>
What do you mean?!!!
/forums/images/graemlins/grin.gif
/ Operating JD 448 Backhoe #15
I've got almost 3000 hours on my 4600 and I've been abusing the loader from day one. I have not, knock on wood, had one problem with it.
/ Operating JD 448 Backhoe #16
</font><font color="blue" class="small">( Having the bucket down and the stabilizers helps to eliminate that side to side sway. )</font>
That's what I was thinking...having them down at least FIRMLY against the ground. Otherwise, like you said...rocking back and forth.
I figured this one be one of those controversial subject where everyone has a correct way to do it, and everyone's correct way is different /forums/images/graemlins/smile.gif
/ Operating JD 448 Backhoe #17
</font><font color="blue" class="small">( I still haven't tracked down the 448 manual online.
Digging Position
)</font>
I don't have the operator's manual, but I do have a copy of the dealer's manual to show the complete specs for the 448, it almost reads like a manual.
It's too large to post here, but I'll be happy to email the pdf file to you, it's 248kb and 12 pages.
Pat
CATERPILLAR 525B DUAL ARCH SKIDDER (A64276)
CATERPILLAR 525B...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
(1) UNUSED 9.5-24 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED 9.5-24...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2008 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2008 Stertil Koni...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
