One Touch 3rd function kit info needed?
   / One Touch 3rd function kit info needed?
okay this was not working to post directly as .pdf, some pages too large, so i have split into a 4 part self extracting file using winrar, but had to then zip each of those files to get the .zip extension required to post.
Download all 4 files, unzip all 4 into the same directory, then click on the file "3rd function kit.part1.exe" and you will be prompted to extract the file to a directory of your choice.
Hope you all can follow this...
File 1: 3rd function kit.part1.exe 98 k bytes (91 k zipped)
File 2: 3rd function kit.part2.rar 96 k bytes
File 3: 3rd function kit.part3.rar 96 k bytes
File 4: 3rd function kit.part4.rar 93 k bytes
enjoy
Almost there...here is 3rd file...
Whew...here it is the last file...
   / One Touch 3rd function kit info needed? #15
Hmmm, I could only open the first two /forums/images/graemlins/frown.gif
Sorry about that, when I went to post the .pdf pages, so many have color pictures that even a single page was larger than the 100,000 byte attachment limit.
I posted the entire diagram set in 4 parts, zipped (compressed).
If you look just a few posts back you will see them, all 4 posts lists the 4 files you need.
You will need to unzip each file into the same folder (directory).
Then click on the file ending in .exe and it will self extract from the 4 files the entire 15 page .pdf document.
If you have never worked with multi part archives before it can be a bit confusing, but not hard to pick the basics.
Gary
Adams Tilt Trailer (A56436)
Adams Tilt Trailer...
208315 (A58376)
208315 (A58376)
2018 Dodge 5500 Bucket Truck 4WD (A56436)
2018 Dodge 5500...
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
Forklift (A59228)
Forklift (A59228)
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
