one slow cylinder
/ one slow cylinder #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i have a bobcat quick att. on my loader ...today i took off the forks and was lineing up the bucket and i noticed on of the dump cylinders was real slow....it was not matching up with the other ,,,any ideas on what this could be ??? thanks for the help bruce
/ one slow cylinder #2
When you have 2 cylinders connected hydraulically but not mechanically, one will almost always ( like 99% of the time) lag behind the other. This is perfectly normal and nothing to be concerned with.
There are so many factors, hose length, cylinders not being exactly the same, basically a hundred variables. As a matter of fact, I don't know if I ever saw 2 cylinders connected hydraulically but not mechanically extend and retract the same.
/ one slow cylinder
thanks for the help.... it may have done this all along ...this my be the first time i noticed it,,,,,,thanks bruce
/ one slow cylinder #4
I never have either. I would call this perfectly normal behavior.
/ one slow cylinder #5
Most loader manufacturers have figured out it is a lot handier for the operator when the two sides of the QA unit are tied together mechanically.
/ one slow cylinder #6
My forklift's tilt cylinders are like that. If you watch, one side is always ahead of the other. If you look, the one that extends/retracts faster probably is closer to the valve/supply or has a shorter hose.
/ one slow cylinder #7
Is this with the mast on the truck? If so, your rod ends need to be adjusted. Over time, you can damage the mast bushings.
New/Unused Electric Winch (A65583)
New/Unused...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
