one slow cylinder
/ one slow cylinder #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i have a bobcat quick att. on my loader ...today i took off the forks and was lineing up the bucket and i noticed on of the dump cylinders was real slow....it was not matching up with the other ,,,any ideas on what this could be ??? thanks for the help bruce
/ one slow cylinder #2
When you have 2 cylinders connected hydraulically but not mechanically, one will almost always ( like 99% of the time) lag behind the other. This is perfectly normal and nothing to be concerned with.
There are so many factors, hose length, cylinders not being exactly the same, basically a hundred variables. As a matter of fact, I don't know if I ever saw 2 cylinders connected hydraulically but not mechanically extend and retract the same.
/ one slow cylinder
thanks for the help.... it may have done this all along ...this my be the first time i noticed it,,,,,,thanks bruce
/ one slow cylinder #4
I never have either. I would call this perfectly normal behavior.
/ one slow cylinder #5
Most loader manufacturers have figured out it is a lot handier for the operator when the two sides of the QA unit are tied together mechanically.
/ one slow cylinder #6
My forklift's tilt cylinders are like that. If you watch, one side is always ahead of the other. If you look, the one that extends/retracts faster probably is closer to the valve/supply or has a shorter hose.
/ one slow cylinder #7
Is this with the mast on the truck? If so, your rod ends need to be adjusted. Over time, you can damage the mast bushings.
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2011 Caterpillar 420E Backhoe (A64194)
2011 Caterpillar...
2023 Bobcat E88 Excavator (A65579)
2023 Bobcat E88...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
