OMG, already thinking of winter
/ OMG, already thinking of winter #181
Minus 26c windchill this afternoon. Changes my plans completely. Had a long list of outside tasks.
/ OMG, already thinking of winter #182
/ OMG, already thinking of winter #183
/ OMG, already thinking of winter #184
Yes it would, especially to me thats most of what I get paid in from the farm, prime Angus beef and some pork.
/ OMG, already thinking of winter #185
With Global Warming, ticks are slowly making their way to Alaska. The brown recluse spider has made an appearance and I hope I never meet the Lone Star Tick.
/ OMG, already thinking of winter #187
This is how our street looked this afternoon. :)
/ OMG, already thinking of winter #188
Sure glad I live in Alaska where we have hardly any snow. I hate that white devil!
Well we have some warm days so I thought I would grease snowblower, had 1 fitting on subframe pointing at frame so I put a 45 degree fitting in place but on drive shaft ujoint next to gearbox has the plastic sleeve over it and I can't get that cover to slide back to access the fitting, is it a brute strength and yank back or another trick, had to walk away for abit
/ OMG, already thinking of winter #190
I'm assuming the plastic sleeve is the pto shaft guard.
Some of those are designed to be disconnected and moved to lube the joint, some have to be rotated on the shaft to line up a hole to reach the fitting,
some you may need to disconnect the pto shaft from the tractor and swing the shaft all the way to one side or the other to access the grease fitting.
/ OMG, already thinking of winter #191
70 yesterday. Forecast for 70 today. Then 40s for next week with 30-ish overnight. Waiting the the winter galoshes to drop come late Jane and Feb.
/ OMG, already thinking of winter #192
We've been warm here but had enough base to keep things nice. Seems we've had 100" for the year.
/ OMG, already thinking of winter #193
Knew some guys in the late 70s that had been at K.I. Sawyer years earlier. The stories they told about the plows and the piles .......
/ OMG, already thinking of winter #194
Been kinda lucky here so far bare ground 3" snow here and there and no snow storms in sight till January...now that's the winter I like. :)
Wife went to use snowblower and she called me and said tractor beeps and keeps shutting off, took abit but finnally figured out it's the seat switch, she has to move seat around to get weight in right spot in order for it to work but even turning around takes weight off turning tractor off, any ideas to make it less sensitive?
/ OMG, already thinking of winter #196
Bypass it.
I thought about putting a switch that could bypass it but wife doesn't like that idea but if I can't find a solution i might
/ OMG, already thinking of winter #198
I'm not a fan of seat switches. Maybe if you had kids running it? But then, they would suffer with the problem of it periodically shutting off too.
/ OMG, already thinking of winter #199
40-50 lbs of lead is not very large. Make up two (one will be hard to lift) "cushions" with lead birdshot sown in and a soft layer of foam on the top cushion. Easy to take on and off and will raise the seat less than an inch. One may be enough...try and adjust if needed.
Depending on your seat design, adding lead ingots to the edge would work too and do not change ergonomics. BTW, I use lead as a counter weight on my ballast box.
/ OMG, already thinking of winter #200
Bypassing the seat switch was one of the very first things I did on my tractor. I am 5'9" 230lbs, and I still set it off when turning around in my seat, or bouncing around in rough terrain. That switch lasted about 10hrs!
KBH Tank Trailer (A61307)
KBH Tank Trailer...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
TANK MANIFOLD (A58214)
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
