Oliver 50 Baler Help!
   / Oliver 50 Baler Help! #1
Dark Horse
Sunbury,Pa
1975 Massey Ferguson 255
I just purchased a Oliver 50 Baler which i was told was in good working order, but having some trouble. Im having a hard time finding a operators manual online, and also having trouble with the right twine knotter. It forms knot but doesnt pull it off the tougue. Can anybody help me out?
Thanks.
Sorry if this is posted in wrong location couldnt find a section on oliver.
   / Oliver 50 Baler Help! #2
Years ago we had this problem with an Oliver 50T. The shoulder where the tongue roller rides on the knotter frame had worn off so the tongue wouldn't open. The dealer at that time built up that shoulder with braze and the knotter worked fine for years afterword. Also may want to make sure the wiper arm has the wiper plate rubbing snug against the bottom of the bill hook. If that's not tight, the wiper arm can be modeled (bent) to move the plate tighter. Hope that helps.
Is the 50T the Same at the 50?
I believe the tongue is opening because when i finally saw it was missing the was 3 or 4 strings in it.
   / Oliver 50 Baler Help! #4
Yes, same model. "T" is for twine tie. Sure sounds like the wiper is not doing it's job. If you have any more details, it might be easier to add some ideas.
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2020 Chevy Silverado (A56438)
2020 Chevy...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
2018 Ford Explore AWD SUV (A59231)
2018 Ford Explore...
