Older Stihl getting hard to start
   / Older Stihl getting hard to start
Better yet, just store all your equipment with synthetic gas in them. I use Echo Red Armor, 50-1 in everything including my over wintering gas powered equipment other than chainsaws. I drain the e-gas out and put it in the vehicles and replace it with Red Armor and in the spring they start right up no issue. No gunked up carbs or flabby fuel lines either and if you need chainsaw parts, I recommend 'Sawzilla'. They specialize in parts for older chainsaws.
Thank you so much, I appreciate it.
I'll have to try cleaning my spark arrestor. I don't think it is clogged enough to cause hard starting but if it is partially clogged it could certainly affect the power and rpm from the saw. FYI, the easy start model has a wind up feature for starting. So to start you pull slowly on the starter handle and when the spring inside has wound up enough it lets go and turns the engine over. I would rather not use this type of starter but with my wrists it is a true pain saver.
Eric
Thanks, I agree, I have a bad shoulder and pulling a rope won't work.
   / Older Stihl getting hard to start #35
The issue around here is, non e-gas is really not available, I'd have to drive 30+ miles to get it and even then it's prices at least a buck higher per gallon than premium. Around here it's called 'Rec Gas' Guess I could buy Aviation fuel which is e free but the closest airport is still 25 miles away. Easier for me to just buy canned gas and there is an Echo dealer up town so I buy gallons from him.
If I used my saws everyday, I'd just buy e10 and mix in premix bottles but I don't so the canned gas makes good sense for me.
   / Older Stihl getting hard to start #36
Sea Foam and can't recall the name of the other one, but they are good fuel stabilizers for less than a year storage.
   / Older Stihl getting hard to start #37
A lot of old arthritic hands here! This 71 yo has them too.
I had a knuckle replacement in my rt index last year and that really is a good fix.
This year I had arthroplasty on my left thumb in jan and that is healed quite well too. That took out some little bone I think it is called the trapezium and replaced it with some tendon.
With that knuckle replacement I was able to use my saws with the right finger on the trigger again instead of trying to use the middle finger when doing wood this year.
Bill
   / Older Stihl getting hard to start #38
I have similar aged Stihl, think it is the 160 with easy start. Starting was getting to be tougher and it started lacking the power when cutting. This saw does not get used regularly. Stihl no longer stocked the carburetor, but did stock most of the gaskets and fuel filter. Disassembled cleaned and replaced what I could. Didn’t find any smoking guns, but it starts and runs great now. Dealer did say there was one tube attached to carb ( forget which) that shrinks back due to ethanol fuel, though mine was ok. Took a little time, but it was worth the effort as the rest of the saw was in good shape, even though it’s a homeowner style saw.
   / Older Stihl getting hard to start #39
How much cutting do you do? Does you Stihl have 100s of hours on it? If it still in good shape, it likely routine maintenance like mentioned above. Don’t forget to remove the exhaust (and spark arrestor screen) for soaking / cleaning. When the spark arrester is clogged it will never start. And the non-ethanol fuel work great.
The Milwaukee battery saw is fantastic, for smaller jobs. Cuts just as fast and strong as my Stihl, but doesn’t run as long.
   / Older Stihl getting hard to start #40
I'll second a vote for a battery saw of similar size. I own two 180's. Nice easy start saws but not very powerful.
I also own two 660's. They have seemed to put on a lot of weight in the last 5 years.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
BALLMORE 4' FOLDABLE ROLLING LADDER STAND (A58374)
BALLMORE 4'...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SHOP TOOLS (A58216)
SHOP TOOLS (A58216)
