Older Stihl getting hard to start
   / Older Stihl getting hard to start #21
I’ll jump on the “spark plug” bandwagon. Start with the cheap stuff.
Agreed. But in this case he had already replaced the plug before first post.
   / Older Stihl getting hard to start #22
Sounds to me like 'hardening of the fuel delivery arteries'.... Like I said, Sawzilla will have all the parts to rebuild it for a very reasonable cost. Not that I have issues starting my venerable 028 I bought new way back in the early 60's but it was time for a new part upgrade and Sawzilla had everything I needed.
The 028 I own came factory with a heated handgrip. Stihl only made the saw for I believe 3 years. it's a screamer and I'm very fond of it.
   / Older Stihl getting hard to start #23
I have changed new plugs in the past and found that once in a while, you get a defective plug. But by age and description, I agree it does sound like a fuel/air issue.
   / Older Stihl getting hard to start #24
Spark plugs today aren't not all created equal either. The venerable Champion plugs have turned to junk. I'd buy an Stihl plug or an Japan made NGK (got to be careful with NGK as some are made in China.
   / Older Stihl getting hard to start #25
I have 180 for limbing but don't think it is an easy start model. I found that when running poorly, the spark arrester screen behind the muffler gets really plugged up. You can take it out and burn the crap off with a propane torch and that makes a big difference in how it runs. Last time I just "forgot" to put it back in as I cut my firewood in the late winter so not much of a spark hazard then, CARB/EPA.
My main saw is an old 034 Super AV and that is still a great saw. Not sure when they were made but I bought it used in a stihl dealer shop about 25 years ago.
Bill
   / Older Stihl getting hard to start #26
My neighbor had a 20 year old Stihl chainsaw that was getting harder and harder to start. If the saw had been running for 10 minutes or so and then shut off to refuel, it was impossible to start until it had cooled off. We rebuilt his carb, installed a new plug, and he always burned fresh gas. Still no luck! I looked at the coil and noticed the gap between the contacts and flywheel looked excessive. The coil was not testing well, so I put a new coil in and gapped it correctly. The saw now starts like new and restarts with one pull once warmed up.
I always space my mag gap with a business card.
   / Older Stihl getting hard to start #27
Bill
If you use canned gas instead of the pre mix bottles and pump gas, the carbon issue on the spark arrestor screen will vanish. I never clean mine, ever. Of course you still have to have the correct a/f ratio.
   / Older Stihl getting hard to start #28
I haven't read each answer/reply to this thread, but I know 13 years ago I could pull harder and faster on my chainsaw pull rope. That is to be considered also.
   / Older Stihl getting hard to start #29
Bill
I'll have to try cleaning my spark arrestor. I don't think it is clogged enough to cause hard starting but if it is partially clogged it could certainly affect the power and rpm from the saw. FYI, the easy start model has a wind up feature for starting. So to start you pull slowly on the starter handle and when the spring inside has wound up enough it lets go and turns the engine over. I would rather not use this type of starter but with my wrists it is a true pain saver.
Eric
I have the same saw that's about the same age. It too got harder to start. I finally tried Seafoam in the tank. I had little hope but it fixed the hard starting problem. After a couple weeks it started to get hard to start again and I used more Seafoam and the second use seems to have fixed the problem for good. It has been easy starting for the last year or so. BTW, I bought the saw because I have bone on bone joints in both wrists and the easy start feature makes life much easier, way less pain when pulling the starter cord.
Eric
Thank you so much, I'll try it.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
Nissan Forklift (A55973)
Nissan Forklift...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
