Older Stihl getting hard to start
   / Older Stihl getting hard to start #11
Storing any 2-cycle engine with today's ethanol-mix fuel in the system is problematic at best.
I empty the tank then run the engine dry. Tru-fuel is best, even though more expensive.
A local gas station has ethanol-free fuel for $6/gallon___, no_ thanks anyway.
I have a portable generator that always ran great; forgot to empty the tank and drain carb. Now the carb needs replaced and all the fuel line are crumbling off.
   / Older Stihl getting hard to start #12
Store your equipment with ethanol shield, not stabil.
   / Older Stihl getting hard to start #13
I run 93 octane pump gas (E10?), and have had zero issues with any fuel lines on any of my saws. I have replaced two carburetors on BG-56 blowers over 15 years, which seems to be par for the course on that model, and once on crappy McCullough weedwacker, but never any of my Stihl or Husky saws.
I’m sure non-ethanol gas is at least theoretically better in many ways, but I’ve never had any issue with pump gas in any of my saws. I usually fill them in the fall, use them regularly October thru March, then drain, run them dry, and shelf them for the summer.
   / Older Stihl getting hard to start #14
Better yet, just store all your equipment with synthetic gas in them. I use Echo Red Armor, 50-1 in everything including my over wintering gas powered equipment other than chainsaws. I drain the e-gas out and put it in the vehicles and replace it with Red Armor and in the spring they start right up no issue. No gunked up carbs or flabby fuel lines either and if you need chainsaw parts, I recommend 'Sawzilla'. They specialize in parts for older chainsaws.
   / Older Stihl getting hard to start #15
You will at some point, bank on it....
   / Older Stihl getting hard to start #17
Yeah, I suspect you’re right. But when a new carburetor costs little more than just ONE gallon of canned fuel, let alone the hundreds of gallons of fuel I’ve burned through, I’m still miles ahead when I do! :p
   / Older Stihl getting hard to start #18
My neighbor had a 20 year old Stihl chainsaw that was getting harder and harder to start. If the saw had been running for 10 minutes or so and then shut off to refuel, it was impossible to start until it had cooled off. We rebuilt his carb, installed a new plug, and he always burned fresh gas. Still no luck! I looked at the coil and noticed the gap between the contacts and flywheel looked excessive. The coil was not testing well, so I put a new coil in and gapped it correctly. The saw now starts like new and restarts with one pull once warmed up.
   / Older Stihl getting hard to start #19
Guys, I have a 13 year old Stihl 180MS-C (easy start) When it was new it required 2 pulls to start. When it was 5 years it took 5 or 6 pulls. Now it's 13 years and I pull about 10-20 times. Sometimes I smell gas so it's flooded. I've changed plugs and run Staybil and Techron additives (always have) BTW, I've read that leaving rubber fuel lines dry will harden/crack them so I have always topped off the tank when it sits for 2-4 months.
Do I need a carb rebuild or a new saw? Thanks
I have the same saw that's about the same age. It too got harder to start. I finally tried Seafoam in the tank. I had little hope but it fixed the hard starting problem. After a couple weeks it started to get hard to start again and I used more Seafoam and the second use seems to have fixed the problem for good. It has been easy starting for the last year or so. BTW, I bought the saw because I have bone on bone joints in both wrists and the easy start feature makes life much easier, way less pain when pulling the starter cord.
Eric
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Toro Ground Master 4000D (A56857)
Toro Ground Master...
Mini Skid-Steer Concrete Mixing Bucket (New/Unused) (A59225)
Mini Skid-Steer...
16' METAL TRUCK BED (A52708)
16' METAL TRUCK...
10,000lb. forklift skytrack (A56857)
10,000lb. forklift...
