Older Kioti fluid question
/ Older Kioti fluid question #1
TWilk
1989 Kioti LB2214
Good morning, new member first post… i got my first tractor almost two years ago, ita a Kioti LB2214 and i think the year model is somewhere around 1989. It’s mainly used for mowing certain areas at my family hunting property! Great tractor for what i need, zero issues and has never not started at least yet! It does seem to have what i believe is a little hydraulic leak and it appears to leak only when using PTO using brush hog! My question is what kind of fluid do i need to get to top it off or does it even matter? Also there are two caps both labeled “oil” one in the rear above pto and one up front kinda between your legs below the shifter (see pics). Are both these caps where i would fill with the Hydraulic “oil”. Also what motor oil does it require? Sorry if the questions are kinda stupid, just learning, and don’t wanna screw anything up! Thanks alot
Of
/ Older Kioti fluid question #2
Can't help with your specific questions. I'd look around on the web to see if I could locate an OM for your tractor or failing that ask your dealer.
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
