Older Case 222 engine questions
/ Older Case 222 engine questions #1
kubota_krazy
Michigan
Kubota L2800
I have a older case 222 with 12hp Engine Model K301A Ser#4298204 that is useing lots of oil. The cyl appers fine as does the piston.. but lots of oil in the upper piston area..Could I be losing oil through the valve guides? Or is the oil ring most likely the issue?? trying to keep from ripping the upper 1/2 apart. Alos what is the spec to torque the head bolts down to
I am looking for parts, Piston, rings etc. Does anyone know where to get parts and or a maint. book showing engine parts break down, torque values etc...
Thanks for any help... I want the old case to live..
/ Older Case 222 engine questions #2
Go to kohlerengines.com and download one fine service manual for free :)
I have a K301 in the same condition. It is the rings on mine. Valve guides usually stick or gall up vs letting oil into the cylinder. You will see why when you tear into it.
I am planning on rebuilding mine this winter, gotta keep on using it till then though. I will get it bored, etc and then get a rebuild kit to match the bore.
Ben
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A67148)
2019 HINO 195 18FT...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2000 MACK RD688S DUMP TRUCK (A64278)
2000 MACK RD688S...
2006 Ford F-250 Knapheide Service Truck with Liftgate (A64556)
2006 Ford F-250...
