Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #1
Deanes
NH T2410 55 Hp, FEL and cab
The machine randomly just stops like someone turned the key off. Sometimes it restarts ok, but other times it just cranks and cranks. I have removed and tested the fuel shutoff selenoid. It seems ok when I use a jumper to it from the battery. I suspect it is a wiring problem, but the wires disappear into a big sheathed cable, so I don't know how to find the culprit.
My question is it ok to bypass the wiring system and run a switched line directly from the solenoid to the battery or the key?
Changing parts to find the problem is prohibitive. That little solenoid costs over $600.00!
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #2
Is this a diesel or gas engine.
Gas and diesel engine have different causes for sudden stop.
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #3
I would use a fused switched wire to power the fuel shutoff solenoid.
Is your solenoid a 2 wire or three wire version? If 3 wire you need to determine which wire is start and which is hold or run circuit. Since you say it sometimes won’t start I would check for power to the solenoid when it won’t start or run to verify this is the problem.
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #4
Bad boy says they use Perkins Diesel engines is the reason I asked if the engine was gas or diesel.
If the engine is a Perkins the Solenoid cost is not that bad.
If a Cat Diesel, Bad boy wants $259.95..
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #5
I believe CAT bought Perkins several years ago so could be both.
It's 2 wires. Thanks for the info.
It is a Cat 28 hp diesel. Maybe that solenoid would work, but this engine calls for part 015-2504-00. Over $600.00
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #9
Sounds like your luck is the same as mine. Only the most expensive part will work. Bummer.
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #10
On most of the small diesel engines you have a fused relay powering a device called a controller which in turn powers the solenoid. The two wire coming to the solenoid both have voltage. When you turn the key on the voltage is applied to the solenoid by one of the wires. this extends the plunger which moves he spring load rail in the pump allowing diesel to flow. With a OHM meter with the ground on the negative battery post check the wires for voltage with the switch. The other wire is a holding wire to hold the solenoid with pressure on the rail to keep it open,
You can usually remove the solenoid and stick you little finger in the hole and push the fuel rail open and start the unit and when you finger is extracted the rail closes and the engine stops. a firm piece of stiff rubber hose will work also just be careful and don't start cramming and pushing and damage internal pump components.
Your voltage should go from the relay to the controller to the solenoid. Trace the wire backward from the solenoid and you should find the controller. A lot of the controllers are white .
Hope i haven't confused you to much.
   / Older Bad Boy Commercial machine with Cat Diesel fuel cutoff problems #11
To answer your question,
Yes, u can run a new fused switch, seeing it’s a 2 wire solenoid..
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2003 McCormick XTX 185 XtraSpeed Tractor (A61307)
2003 McCormick XTX...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
