Oil & Fuel Old diesel fuel
/ Old diesel fuel #1
fuseboxer
Gaines, Michigan
two john deere Sabres (2554-Scotts) and 4410 john deere ,Allis Chalmers WD , 5' Cub Cadet Zero turn
We had a very mild winter and little snow last year in Michigan and only used my JD4410 once and that was probably not necessary. Snow melted in the next few days. My question is that I have old fuel that is at least 12 months old in my tractor. I use the usual fuel additives that many use and recommend. Looks like I have only had about 6 hours of use in over a year. Should I change the fuel? Just drain the water skimmer? Starts and runs good. What would you do? ---Fuseboxer :confused3:
/ Old diesel fuel #2
me? I'd drain water out and see if she ran. if so.. treat again and add some fresh and go.
if she don't like it.
change filter. drain fuel and save.. and refill with good fuel.. bleed, and use the old fuel as top off after straining it for solids.
check tank and tap for biologicals..
/ Old diesel fuel #3
I'd just go ahead using it.
/ Old diesel fuel #4
For once I agree with LBrown, just go ahead and use it. Keep an eye on the water separator but if it looks good go for it.
/ Old diesel fuel #5
Only thing that affects diesel are contaminants such as dirt or water. Water contributes to algae growth. I agree just check water separator and use the fuel.
/ Old diesel fuel #6
That's all you need to do with diesel.
/ Old diesel fuel #7
Just order some PRI-G (gas) and PRI-D (diesel) fuel stabilizers that will keep fuel/gas fresh for 10+ years. I researched and found it and purchased on Amazon.
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
2009 Kershaw 75-G2 Sky Trim (A65579)
2009 Kershaw 75-G2...
