Mowing Old BX23 vacuum bagger attachment level
/ Old BX23 vacuum bagger attachment level #1
tshep
Richmond, VA
BX23 MLB
Hi all - I have the above (and a newly level tractor from tire repairs).
I now can confirm that the vacuum assembly wants to sit low to the right side where the offcenter weight is - on the tractor. This is the older triangle to the top / dual link arm to the bottom type mount that is so hard to get mounted - no lift or hydraulic adjustment is built-in or possible.
I can get most of it out by cranking on the adjustable link limit link/'chain' piece - but that leaves it very tight and very stressed. Is this normal?
Anyone have a better way to level? I'm trying to get where the bagger doesn't affect the chassis so it doesn't affect the mower, etc and all is level with or without the bagger.
/ Old BX23 vacuum bagger attachment level #2
You are doing the right thing. But if you are tightening on one side you should also be loosening on the other side. That way you don't get it very tight. I get it level by "loosening" and "tightening" both sides as necessary and then just tighten one side sufficiently so it doesn't move around but is not TIGHT.
Hedge Posts (A65640)
1952 John Deere A Tractor (A66408)
1952 John Deere A...
72in. Fine High Side Skeleton Skid Steer Bucket (A65640)
72in. Fine High...
Demco Lowboy Trailer (A65563)
Demco Lowboy...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
