Oil use
/ Oil use #11
my 2210 does not leak but I do burn it. Use a few ounces every hour. Actually see it out the tail pipe if I let it idle low and then crank it up. Runs good but probaly needs rings or a valve job. I just keep puting oil in it for now, pretend its like a 2cycle motor in oil usage. have fun. erick
/ Oil use
The reason I asked in the first place is that mine had a few drops of oil on the bottom of the bellhouseing. I havn't had it long enough to find out if the real seal is leaking or not, as I don't have enough hours on it yet to know. And with the rain we have been having I don't know when I will know. I was useing it trying to move some gravel up a, hill, my road to the house, when I saw it. As it was mostly running up a fair grade, that might have caused it, I'll find out in time, I guess. I have run it, doing some brush hoging since for a couple of hours or so, and didn't see anymore.
/ Oil use #13
I have changed the oil in my 2010 twice since I bought it - both times at 40 hours of use and have never had to add any between changing. It had 1120 hours when I bought it and now had just over 1200. No leaks and no using.
William
2020 Bobcat E35 (A60462)
2020 Bobcat E35...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
iDrive TDS-2010H...
2020 Case 5550 Trident (A61307)
2020 Case 5550...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
