Oil suggestions
/ Oil suggestions #1
Andrewnyc
Allmand brothers 425
Hello,
have an allmand 425 Tlb - small loader excavator, kubota diesel d1105, Eaton had hydrostat, Ross ME series drive.
the manual says for hydraulic oil requirements, use a sae20/ iso 68/ gl-4 “ high quality multipurpose fluid “ Any ideas on a reasonably priced oil? 12 gallons, I think 10 with a change.
it sat for a long while and when I replaced a stabilizer hose, the oil in the stabilizer cylinder was brown like it was a little rusty, but it’s not burnt. Do I need to flush these things or just bring it up to temp and change the filters and fluid?
thanks,
Andrew
/ Oil suggestions
Ok so I found something available not too far away mobil delvac tractor hydraulic fluid. It’s gl-4, and almost the iso I need. I called tech, but language barrier, they said it’s 55 centistokes so I figure that means it’s like an iso 55 is that close enough to 68?
/ Oil suggestions #3
Cant hurt to drain anything you can if it looks contaminated.
/ Oil suggestions #4
I realize this is months later but I used a Napa gl4 hydraulic fluid. I had used tractor supply in the past just to top off but I did not like what I saw when I got to the bottom of the bucket. It looked like a lot of particles in the traveler tractor supply bucket.
/ Oil suggestions #5
Wow. That's some serious contamination. I wonder how many smaller particles were suspended and poured into your machine?
/ Oil suggestions #6
I ended up draining the whole machine not long after that and changing all the filters. I’ll gladly pay the extra for the Napa stuff from here on out.
/ Oil suggestions #7
That looks like used oil. My guess is that a scammer bought a bucket of oil, changed it, poured the old oil back into the bucket, carefully cleaned it to make it look new and took it back to Tractor Supply for a refund.
/ Oil suggestions #8
The bucket cover had the plastic ring around it and all the tabs were super tight. I actually purchased two 5 gallon buckets when it was on sale. I think it was just sitting a verrryyy long time on the shelf and then another two months or so by time I had needed to use it. The color in the photo I believe to be mostly caused by the lighting and reflection of a plywood roof. I was more concerned about the little particles along the edges that looks like a pan from gold mining.
/ Oil suggestions #9
Easy for me to say, but honestly I would have taken that back to the retailer. Not just for replacement, but for whatever it took to get that crap out of the machine, along with filter expense.
/ Oil suggestions #10
Its oil..its alreaty thousands of years old before it goes into the bucket.
I have used tractor supply oils and other cheap oils and dont see any of the stuff you found in that bucket.
/ Oil suggestions #11
T looks like the additive package has separated out I've had that happen to me before with 5gall buckets of delvac that sat for a long time b4 I used it.
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2016 KUBOTA SVL 90 SKID STEER (A65053)
2016 KUBOTA SVL 90...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2009 International 4300 Digger Derrick (A62613)
2009 International...
