Oil suggestions
/ Oil suggestions #1
Andrewnyc
Member
Allmand brothers 425
Hello,
have an allmand 425 Tlb - small loader excavator, kubota diesel d1105, Eaton had hydrostat, Ross ME series drive.
the manual says for hydraulic oil requirements, use a sae20/ iso 68/ gl-4 “ high quality multipurpose fluid “ Any ideas on a reasonably priced oil? 12 gallons, I think 10 with a change.
it sat for a long while and when I replaced a stabilizer hose, the oil in the stabilizer cylinder was brown like it was a little rusty, but it’s not burnt. Do I need to flush these things or just bring it up to temp and change the filters and fluid?
thanks,
Andrew
/ Oil suggestions
Ok so I found something available not too far away mobil delvac tractor hydraulic fluid. It’s gl-4, and almost the iso I need. I called tech, but language barrier, they said it’s 55 centistokes so I figure that means it’s like an iso 55 is that close enough to 68?
/ Oil suggestions #3
Cant hurt to drain anything you can if it looks contaminated.
/ Oil suggestions #4
I realize this is months later but I used a Napa gl4 hydraulic fluid. I had used tractor supply in the past just to top off but I did not like what I saw when I got to the bottom of the bucket. It looked like a lot of particles in the traveler tractor supply bucket.
/ Oil suggestions #5
Wow. That's some serious contamination. I wonder how many smaller particles were suspended and poured into your machine?
/ Oil suggestions #6
I ended up draining the whole machine not long after that and changing all the filters. I’ll gladly pay the extra for the Napa stuff from here on out.
/ Oil suggestions #7
That looks like used oil. My guess is that a scammer bought a bucket of oil, changed it, poured the old oil back into the bucket, carefully cleaned it to make it look new and took it back to Tractor Supply for a refund.
/ Oil suggestions #8
The bucket cover had the plastic ring around it and all the tabs were super tight. I actually purchased two 5 gallon buckets when it was on sale. I think it was just sitting a verrryyy long time on the shelf and then another two months or so by time I had needed to use it. The color in the photo I believe to be mostly caused by the lighting and reflection of a plywood roof. I was more concerned about the little particles along the edges that looks like a pan from gold mining.
/ Oil suggestions #9
Easy for me to say, but honestly I would have taken that back to the retailer. Not just for replacement, but for whatever it took to get that crap out of the machine, along with filter expense.
/ Oil suggestions #10
Its oil..its alreaty thousands of years old before it goes into the bucket.
I have used tractor supply oils and other cheap oils and dont see any of the stuff you found in that bucket.
/ Oil suggestions #11
T looks like the additive package has separated out I've had that happen to me before with 5gall buckets of delvac that sat for a long time b4 I used it.
1999 Chevrolet Step Van Food Truck (A61568)
1999 Chevrolet...
New/Unused 60in Pallet Forks (A61166)
New/Unused 60in...
AirCo Radiograph Track Burner (A60353)
AirCo Radiograph...
(2) UNUSED 420/85R30 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2023 CATERPILLAR 279D3 SKID STEER (A62129)
2023 CATERPILLAR...
