Oil & Fuel Oil Sending Unit
   / Oil Sending Unit #1
rhugg
MF 1010
B7100HST, have 50 psi at operating RPM. Oil light is always on, checked sending unit with wire disconnected it is always grounding. So I need a new sending unit. Is this something I can get at a normal automotive parts place or will I need to wait for and pay for the official orange one?
   / Oil Sending Unit #2
To worry over oil pressures is such a waste of time. The engine will stop if you don't have enough!
Probably a metric fitting without looking. It s your choice.
Kubota price is 16.43
   / Oil Sending Unit #3
If it controls the light then it's an oil pressure switch not a sender. So when you remove the one wire the light goes off...is that correct? Then if you ground the wire the light goes on? If that's the case you need a normally closed oil pressure switch . It's probably 1/8" NPT which is the most common. You can get whatever pressure you want...probably 10 or 15 psi is a good range. I would get one from an auto parts store but I don't think Kubota would charge too much for one...at least call your dealer to find out.
   / Oil Sending Unit
Replaced with Kubota part ($15-20 I forget), all is well. Switch is just a ground so yes when I pulled the wire it goes out. Had the wire been grounding somewhere else it would not have gone out.
Thanks
LOT: (4) Large Wheel Chocks (A59076)
LOT: (4) Large...
Portable Restroom (A54865)
Portable Restroom...
2018 John Deere 2025R Tractor - 647 Hours (A56435)
2018 John Deere...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
ALLISON TRANSMISSION (A55745)
ALLISON...
