Oil & Fuel Oil Sending Unit
/ Oil Sending Unit #1
rhugg
MF 1010
B7100HST, have 50 psi at operating RPM. Oil light is always on, checked sending unit with wire disconnected it is always grounding. So I need a new sending unit. Is this something I can get at a normal automotive parts place or will I need to wait for and pay for the official orange one?
/ Oil Sending Unit #2
To worry over oil pressures is such a waste of time. The engine will stop if you don't have enough!
Probably a metric fitting without looking. It s your choice.
Kubota price is 16.43
/ Oil Sending Unit #3
If it controls the light then it's an oil pressure switch not a sender. So when you remove the one wire the light goes off...is that correct? Then if you ground the wire the light goes on? If that's the case you need a normally closed oil pressure switch . It's probably 1/8" NPT which is the most common. You can get whatever pressure you want...probably 10 or 15 psi is a good range. I would get one from an auto parts store but I don't think Kubota would charge too much for one...at least call your dealer to find out.
/ Oil Sending Unit
Replaced with Kubota part ($15-20 I forget), all is well. Switch is just a ground so yes when I pulled the wire it goes out. Had the wire been grounding somewhere else it would not have gone out.
Thanks
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
2013 Nissan Versa Sedan (A64557)
2013 Nissan Versa...
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 1500 4x4...
