Oil Sender Leak
/ Oil Sender Leak #1
dmccue
Melbourne, Florida
Kioti CK20, Yanmar YM2000, and Sears Garden Tractor 19.5HP
I have a Yanmar YM2000 tractor. After engine warmup I notice an oil leak which appears to be coming from around the oil sender switch.
Is the remedy to replace this switch? If so, is there a special procedure to do this? Is a replacement switch available?
/ Oil Sender Leak #2
It is more than likely leaking where the 2 parts of the switch are put together. I took mine to NAPA and they matched it to another one. They said there was only 2 kinds, One for a light and one for a gauge. It stopped my leak.
Eugene
/ Oil Sender Leak #4
My 1700 had a leak on the sender, I thought it wasn't tight.. tightened it.. cracked it.. got anohter one.. thread taped it for piece of mind, and didn't worry about it after that.
Soundguy
/ Oil Sender Leak #5
A bit of advice on installing an oil pressure sender. Using thread tape is not generally advisable. If a piece were to get loose in the oil system, it could easily plug a small oil passage and starve a bearing. Try using some thread sealer like plumbers use - I think I got some locktite. The mechanics here at Mack Trucks use it exclusively for these types of applications.
/ Oil Sender Leak #6
Actually that is what i did, I used the liquid tape sealer. I never use the real tape anymore, I'm spoiled on the liquid sealer.. it works great. The grey stuff for gasline is pretty decent as well.
I probably should have specified liquid tape.. i just get into the habit of saying 'taping it'. etc.
thanks for the reminder!
Soundguy
2020 Case TV370B (A64126)
2020 Case TV370B...
2022 EZ-GO ELITE...
Bush Hog 13414 (A64126)
Bush Hog 13414...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
